Trouble Codes.... Please help - Hemi Truck Club
Old 04-15-2008, 08:50 PM   #1
nitromud's Avatar
I had a check engine light comeon this weekend. Thank god I bought my Bully Dog Tripple Dog. It say I had codes P0406 and P0585 this weekend. I cleared them and took it for a drive today and the light came on again. Now it has a code P0404. I know what the P0404 and P0406 mean but I don't know how to go about testing them. I haven't been able to find out what P0585 means though. Can someone give me some help on this please????
nitromud is offline   Reply With Quote
Old 04-15-2008, 09:29 PM   #2
Hope this helps.
SYMPTOM
P0585-SPEED CONTROL SWITCH # 1 AND # 2 CORRELATION
WHEN MONITORED
Ignition on.
SET CONDITION
Cruise Switch inputs are not coherent with each other. Example: PCM is reading Switch # 1 as Accel and Switch # 2 as Coast at the same time. One trip fault.
POSSIBLE CAUSES
* Good trip equal to zero
* Speed control on/off switch
* Speed control resume/accel switch
* S/C switch signal circuits shorted to voltage
* Speed control switches
* Clockspring
* Resistance in the S/C switch signal circuits
* Resistance in the (Y215) switch return circuit
* S/C switch signal circuits shorted to the (Y215) switch return circuit
* (V37) S/C switch # 1 signal circuit shorted to (V38) S/C switch # 2 signal circuit
* S/C switch signal circuits shorted to ground
* PCM
gary_lytle is offline   Reply With Quote
Old 04-15-2008, 09:46 PM   #3
nitromud's Avatar
I hate to say it, but.....That thuroughly left me confused. I am used to the big trucks. I am a Peterbilt mechanic and we don't have that many variables. That code has only showed up once and after I cleared it, it never came back on. I am concerned mostly about the P0404 and P0406 codes.
Old 04-16-2008, 12:40 AM   #4
HemiByrd's Avatar
Take a look the these two service bulletins. It could be a bad EGR valve or the PCM may needs to be flashed. My bet is on a bad EGR valve.
TSB 18-010-04 Flash: MIL Illumination DTC's P0403, P0404, P0405, P0406
TSB 18-021-04 MIL Illumination Diagnostic Trouble Codes P0401 P0403 P0404 P0405 P0406
http://dodgeram.info/tsb/2004-index.htm
Old 04-16-2008, 07:49 AM   #5
nitromud's Avatar
Those service bulletins are a great help. Will those be covered by Dodge or would I have to pay for them to do them? Also, do I need to remove the Bully Dog before I take it to them?
