trans up grades - Hemi Truck Club
Old 11-08-2011, 12:53 PM   #1
this may be the wrong section for this topic but i was wondering what people here are doing to there transmissions in terms of up grading. and where people are getting there parts from, im not shure if i will be ok just running stock internals and then just getting a good shift kit and a better converter. also where are people getting shift kits from? im thinking something of a mild kit like a towing kit, or along those lines.
any and all info will be appreciated, thanks for your time.
2000 dodge dakota quad cab 4x4 with 4.10 gears and an auburn lsd in rear axle.
soon to have an 2004 hemi engine swap.
dakota dave is offline   Reply With Quote
Old 11-08-2011, 12:53 PM   #2
Old 11-08-2011, 02:17 PM   #3
I am not a trans guru, but what I see is that the line pressure is key to the life of the trans. Especially when tuning is involved as it modifies the MAP voltage which is one of the key inputs controlling line pressure. I have a Miller test adaptor to monitor line pressure. The pressure fluctuated so much it shortly damaged the sensor I had. But I saw <30 psig at cruise which to my thinking is not enough pressure. My recommendation is to keep a eye on your pressure and understand what makes it fluctuate to reduce clutch slipage. Good luck..
Old 11-08-2011, 04:29 PM   #4
David
ATXHEMI's Avatar
Sharadon performance makes a couple of dif beefed up tranny's and tranny parts. Transgo has shift kits
Old 11-11-2011, 03:15 AM   #5
Mr. Freeze
VA4MEDS's Avatar
Just contact white lightning (Dave) for a tranny tune & get a TransGo re-programing kit.
Dave has worked wonders on mine & a few others in the FL Chapter. Very Highly Recomended.
Old 11-12-2011, 12:36 PM   #6
white lightning's Avatar
Thank You, Al!!
not sure what I can do to a 2000 Dakota's trans, have not tried to tune one yet.
2005 Dodge Ram 1500, 5.7 Hemi, Laramie, QCSB, white, auto tranny, 2x4, 76,000 miles
Mods: APS 2,500 stall, Bosch platinum +3 spark plugs, Taylor shorty plug wires, home-made CAI, SRT-10 hood, PPP Big Valve heads, Crazy Jay cam, 20% u/d pulley, Motive 4.56 gears, Jet 180*F t-stat, e-fan, Trans-Go shift kit, Alto Red clutches, Kolene steels, PML deep tranny pan, Mopar bed liner, Putco bed rails & some other stuff
Diablo Dodge CMR Tuner
white lightning is offline   Reply With Quote
Old 11-12-2011, 12:51 PM   #7
Mr. Freeze
VA4MEDS's Avatar
That's OK 'cause you didn't do a 4th Gen before mine, and I'm as Happy As A Pig In Slop !!
Us Florida Boys have Faith In You !!
Old 11-12-2011, 04:54 PM   #8
Thanks, Al! I appreciate your faith in me.
thing is, some years and models don't have trans support. so sometimes there is no trans file to even try my voodoo on.
