Thrown rod - Hemi Truck Club
Old 03-17-2016, 06:36 PM   #1
Thrown rod
Got a 5.7 with a thrown rod everything looks OK from the bottom and even the cylinder, it did however destroy the oil pan gasket which is nothing but from the opposite cylinder it's got water coming out from under or beside the piston. My question is should I rebuild or get another engine or if someone has had a similar problem.
charles27hall is offline   Reply With Quote
Old 03-17-2016, 07:06 PM   #2
J would pull it apart and inspect everything closely. Maybe a good time for a stroker if the block is still good.
Old 03-17-2016, 07:45 PM   #3
charles27hall
Old 03-17-2016, 08:03 PM   #4
Queen Kima - Whemi BOD
Mrs.Studmuffin's Avatar
Old 03-17-2016, 08:16 PM   #5
Welcome to HTC! Pull it out pull it apart and have a look if it looks ok then have a machine shop put a nice hone on it and stock rebuild it or stroke it!
Old 03-17-2016, 09:25 PM   #6
Old 03-17-2016, 11:14 PM   #7
Right I am only guessing what the head looks like I've only got the oil pan off but it's my first hemi so I'm seeing the ideas but yeah it's feeling like just a rebuild .
Old 03-18-2016, 11:45 AM   #8
Tyler
TYSENUS's Avatar
As long as the machine shop has a very close look at it. I went through two block before we finally received a usable block. The one was extremely hard to see, it had a tiny crack on the oil pan rail.
Good luck!
Mods:
Old 03-18-2016, 12:05 PM   #9
I found an engine for 2200 with a 3 year warranty I'm just gonna do that like 70k miles on it but thanks for the advice guys and gl.
Old 03-18-2016, 12:22 PM   #10
That could be your best option, just check the used replacement real good, make sure it hasn't been patched up for resale. Good luck.
