thought I would post problems durimg head and cam swap FYI - Hemi Truck Club
Old 08-08-2008, 02:04 PM   #1
Ok.
Alternator and A/C units just did not want o come off...the rear threaded bushes securing both were corroded into the mounts on the front timing cover mounts and made levering them off really tough.
Even being careful..but forceful the following.
In the case of the A/C as I levered the unit off I had a short escape of a/c gas from the rear seal on the A/C unit.
It stopped as soon as the unit was levered past the mounting points.
The releases tool for the fuel line was to thick needed to be made shorter to fit between the fuel rail and the fuel pipe.
Ok back to work.
SouthernComfortHemi is offline   Reply With Quote
Old 08-08-2008, 02:34 PM   #2
dr.dred's Avatar
So i guess some penetrating oil on the end threads would be good. Hope the rest goes better. Keep us posted. TAKE PICS!
Old 08-08-2008, 05:54 PM   #3
next issue...I had those special bolts with C-clips and retainer tags to keep the exhaust manifold bolts in place.
Great when you put them on...no problem....PH just try and take them off.....its a real pain.
And Mr Gasket manifold gasket blew on one side...was properly torqued...just burnt through on the rear downpipe head manifold joint.
Using the mopar ones this time hope they hold up better.
Old 08-10-2008, 07:49 PM   #4
dr.dred's Avatar
The Stage 8 bolts? As far as I've read is the Mopar gaskets are the best so far?
Old 08-10-2008, 08:07 PM   #5
well going back together...
Head were easy to change..as long as you remember to remove the earth straps and heat sensor.
Cam come out and in like a dream.
Valve gear was a bit of a muddle got the shafts mixed up....but am using new pushrods so its not really an existing part matching issue.
Only issue was fitting my torque wrench on the rear bolts...got round that in the end.
What I would like is some rough PSC settings to allow for the high compression heads and cam.
Old 08-13-2008, 11:06 PM   #6
dr.dred's Avatar
So????? How's she feel now?
Old 08-13-2008, 11:31 PM   #7
thanks..back and hernia problem so she cant stay on her feet long.....
thanks very much for the interest...
Old 08-13-2008, 11:39 PM   #8
Had to swap mu cam to a 268 as the custom cam I had purchased had issues.
Big negative overlap was causing some people issues especially with high compression heads.
Good old hemifever is doing the tune today...cant wait to install it.
Old 08-14-2008, 07:34 AM   #9
FAhemiST's Avatar
Old 08-14-2008, 07:57 AM   #10
