Swapped/rebuilt 5.7 pics - Hemi Truck Club
Old 08-30-2016, 04:18 PM   #1
Lets see pics of some motors that y'all have swapped your 5.7 out for or have built your 5.7 into. Just curious what everyone out there has built or swapped too. Also the rwhp & rwtp your putting down with your setup.
04 QC/SB stock cats with mufflers cut off right behind the X pipe…..much more to come in the future
04ramhemi4x4 is offline   Reply With Quote
Old 08-30-2016, 04:30 PM   #2
Tyler
TYSENUS's Avatar
I have no dyno numbers.
File Type: jpg 11230850_10152733263752251_373354143966890322_n.jpg (78.5 KB, 15 views)
Mods:
Old 08-30-2016, 05:23 PM   #3
Thats a purdy motor
Old 08-30-2016, 06:23 PM   #4
All I did was a 392 stroker and the blower setup no pictures of mine. Made 510/489 with a blown off boost pipe so no actual accurate dyno numbers here sorry.
Old 08-30-2016, 08:02 PM   #5
James
DakotaJ's Avatar
Here's my 392 in a Dakota. Should be around 500hp at the crack, mid to low 400 at the tires. Never had it dyno'd but will one day.
Old 08-30-2016, 08:53 PM   #6
I see you replaced the oil breather hose to an actual "filter" at the end, does that help it breath better or just for show? Just curious as I have seen quite a few. Also did you remove your motor, clean it and then paint it red? Also what spark plug wires/spark plugs you running?
Old 08-31-2016, 03:10 AM   #7
Did you get the engine back into the truck yet?
Old 08-31-2016, 03:12 AM   #8
500hp at the crack,
Old 08-31-2016, 09:58 AM   #9
Talking
That's a lotta' blow-by
Old 08-31-2016, 01:30 PM   #10
