Swapped PCM to try and troubleshoot an issue and now.... - Page 8 - Hemi Truck Club
Like Tree17Likes
Old 12-15-2019, 02:25 PM   #71
Apologies for the delay. I was out of town for a couple of days.
I swapped the TIPM with no changes. I will test voltage at the ASD and coils and report back.
theboz001 is offline   Reply With Quote
Old 12-15-2019, 06:19 PM   #72
Tested the voltage at the ASD relay. 12.6V key on engine off on terminal 30 of the relay. 0 volts on terminal 87. 14.2V engine running at terminals 30 and 87.
Coil #1 had 14.2V engine running.
While we had the intake snorkle off I had my son try putting it in gear with a little pedal pressure so I could watch the throttle body. We got lucky and it acted up. The butterfly was cycling back and forth while he had steady pressure on the pedal. Voltages at coil #1 and the ASD relays were just as stated above.
Old 12-15-2019, 07:30 PM   #73
Are you still getting a low asd voltage signal on the scanner?
Old 12-16-2019, 05:08 AM   #74
Yes, the ASD signal has not changed either.
While I had my son available to assist he was raising the idle in gear while I was shaking the wiring harnesses by the back of the engine and near the PCM to see if it would indicate a poor connection. Nothing I touched made any difference.
Old 12-19-2019, 06:53 PM   #75
When you are doing your voltage tests ate you using the computer ground or the engine block?
Old 12-20-2019, 03:14 PM   #76
Subscribed...����
smith92rc is offline   Reply With Quote
Old 12-20-2019, 07:50 PM   #77
I was using the body ground. I will see if I can find which wire is the computer ground for the APPS sensor.
Old 12-20-2019, 08:11 PM   #78
Years ago I built my own harness and cross connected the pcm "clean" ground with chassis ground. I also added an external ground wire connecting pcm, heads, TB with cab and chassis ground on fender. Bed to chassis also has additional ground plus solid engine mounts. Do I recommend going to this extreme? .... no... but I don't have ground issues. Everything is grounded to a single plane with no voltage differences. Besides I wouldn't know how to restore the isolated clean ground... lol
Old 12-21-2019, 12:34 AM   #79
Im just reaching for answers at this point since I cant get there to help. It just feels like a ground issue or possibly losing the crank signal at that rpm/load. Where does the crank signal come from? Flex plate or harmonic balancer?
Old 12-21-2019, 08:00 AM   #80
I believe the crank signal comes from a tone ring on the crank itself. The sensor goes into the block on the passenger side.
I do have additional grounds running to the TB, 1 coil on each the passenger and driver side and one from the battery to body. This is in addition to the factory straps on the back of both heads and the one from the engine to frame on the drivers side. I have checked for voltage drop across all of them and found none.
ric3xrt likes this.
