Swapped PCM to try and troubleshoot an issue and now.... - Page 2 - Hemi Truck Club
Like Tree2Likes
Old 11-22-2019, 06:03 AM   #11
ric3xrt's Avatar
I'm wondering if there isn't a ABS sensor going bad....
Old 11-22-2019, 06:30 AM   #12
I had been doing some reading online and found where someone else had a similar problem and their Superchips actually resolved it. I reverted the diablo tune back to stock and used the Superchips tuner to do a tire size change. The first time I tried it came back with an error about the ABS module not being found. I turned the key off and back on, the second time it worked and turned off the blinking ABS light. Changed the tire size back to stock, ABS light still out.
Drove it around a little and the surge/hesitation is still there. Reinstalled the custom tune and the ABS light is still out. Checked for codes and there are none.
Evidently there is a difference between how Superchips and Diablo do tire size adjustments. At least I am back where I started.
Now to try and figure out why it's hesitating/surging. I tried cleaning all of the ground connections under the hood but that didn't help. Verified 5V signal at the APPS sensor. Tried three different APPS sensors and it has the issue with each. Checked for vacuum leaks and found none.
Time to dig into the wiring harness..
theboz001 is offline   Reply With Quote
Old 11-29-2019, 12:59 PM   #13
Is it a engine hesitation or a transmission engagement hesitation? When did the problem first occur? Was anything else done at the same time when it first occurred?
Old 12-01-2019, 06:02 PM   #14
It's an engine hesitation with an occassional miss & stall. Watching the replay of the data logging it looks like the APPS signal changes all over the place at slight pedal pressure. This in turn makes the throttle body % open bounce around.
It doesn't do it at all when in Open Loop (cold), seems to get worse as the engine warms up. I have tried three different APPS sensors, checked all the wiring and cannot find anything wrong.
No codes, not even a pending code after it misses several times in a row.
Attached is an excerpt of one of the data logs showing the pedal position and throttle body positions changing. I don't believe I am moving the pedal when it starts doing this. In fact, I try to keep it steady and keep it acting up in hope it will actually set a code.
I would appreciate any suggestions.
Old 12-02-2019, 02:09 AM   #15
Try cleaning your throttle body. If its got any carbon built up that can cause what you're describing without throwing a code.
Old 12-02-2019, 08:45 AM   #16
I have already done that. Actually, swapped between three cleaned throttle bodies and new gaskets between it and the intake.
Old 12-02-2019, 09:58 AM   #17
Queen Kima - Whemi BOD
Mrs.Studmuffin's Avatar
Old 12-02-2019, 12:39 PM   #18
Did it happen with the 04 ECM?
Old 12-02-2019, 02:09 PM   #19
Yes, just not as noticable.
Old 12-02-2019, 04:59 PM   #20
Does the 04 use a Mass air flow sensor or a map sensor? I dont remember...An over oiled air filter can play hell with mass air flow sensors.
