summer gas - Hemi Truck Club
Old 06-02-2008, 07:44 PM   #1
summer gas
recently i have been having some hesitation upon startup,a shrt lag before the engine fires.my brother has the same truck with 10,000 less miles,he also has the same hesitatation.i have superchips run 91 tune he doesnt,and uses regular gas .both trucks started having hesitation at same time,is the gas different ,if so what should i do ,if anything about it? we also use different gas stations.thanks for any help
shakes is offline   Reply With Quote
Old 06-02-2008, 08:10 PM   #2
madcat's Avatar
summer gas
how many miles? changed the plugs lately, pcv valve, cleaned the throttle body, changed gas stations..... etc....
SO many variables. Start with the easy one, change gas stations/brand, run a bottle of fuel injector cleaner through her.
AND
Old 06-02-2008, 08:17 PM   #3
summer gas
27000 miles ,i thought it might be the gas ,but not sure i always run 91 to 93 throttle body is clean from what i can tell ,i tried using a different station,no change .never missed an oil change ,i use amsoil ,and just cleaned my cai
Old 06-02-2008, 08:32 PM   #4
madcat's Avatar
summer gas
your getting close on needing a plug change (30K maintenance), but that does not answer your brothers truck having the same symptoms.
I know that was noticing a "rough" idle in the mornings with mine, but a plug change @ 50K (LOOONG overdue) seemed to fixed the problem.
Someone may be along in a little while that may be able to help ya out better.
Old 06-02-2008, 10:50 PM   #5
Solar_Ram's Avatar
summer gas
truck is not even broken in yet.
just get some lucas injector cleaner for the gas tank and squirt the throttle body with "Throttle body cleaner" and also clean the pcv valve with it. my plugs lasted over 50k and were still OK.
Old 06-03-2008, 08:17 PM   #6
UPSTATENYHARDCOREHEMI
summer gas
NO your not supposed to us throttle body cleaner or carb cleaner on these throttle bodies. Use brake cleaner only.
Old 06-04-2008, 05:06 PM   #7
madcat's Avatar
summer gas
is this because of our ABS Plastic upper intake? If "carb" cleaner was harmful to plastic intakes, you would think they would put BIG warning label on the can.
What chemically is different between Brake Cleaner, and Carb Cleaner?
Old 06-05-2008, 04:34 AM   #8
summer gas
Not exactly sure but in the shop manual it state to use brake cleaner. Check out the section on cleaning throttlebody and you will see where Hemipup also states this.
http://home.comcast.net/%7Esteveusmc/PCVandTB.doc
Old 06-05-2008, 04:57 AM   #9
nopeitsherhemi's Avatar
summer gas
not sure what is differnt but i know for a fact carb cleaner will 'melt' certain plastics
but brake cleaner does not seem to and i think it evaporates quicker
