Strange Engine Bog And Up Shift??? - Hemi Truck Club
Old 12-26-2011, 05:46 PM   #1
Blkram88's Avatar
I know im going to take some heat from some people, but I would like some answers and im at a loss. My engine bogs and the trans will up shift while at full throttle going around 105-110mph and it kills the acceleration because the shift happens around 4500 5000 rpm (way to early) if I lift off the throttle about 1/4 the trans will down shift and the speed starts to climb again. It doesnt happen everytime though, this time I happened to have a passenger, but I dont think that has anytime to do thing it. What does everyone think?
Performance Mods: Custom CAI, Power wire, Heddmen LT's, Cat delete, Dynojet Wideband 2 A/F Gauge, Custom Bent 2.50" Full Exhaust Into A Dynomax Ultra Flo X Muffler Dumped Before The Rear Axle, NGK 4306 plugs, Taylor '409' 10.4mm race wires, Circle D 2800-3000 Stall Converter, Sonnax Line Booster, 1 Ton Tranny Cooler, Motive 4.56 Gears, Comp cams 268 cam, 6.1L pushrods, 6.1L exhaust valve springs, SCT custom tune.
Wish List: Comp Custom Cam, 85mm TB, Milled And Worked Heads, Bored 40 Over(If Motor Ever Lets Go,) StageIII Valve Body, E Fan(Waiting For Install)
Blkram88 is offline   Reply With Quote
Old 12-26-2011, 05:46 PM   #2
Blkram88's Avatar
Old 12-26-2011, 06:39 PM   #3
Interesting problem. What year is the truck?
Old 12-26-2011, 06:53 PM   #4
Blkram88's Avatar
2005, i was thinking the same, this is the first time it has happened and the other times the truck has been passed 110 it never happened
Old 12-26-2011, 06:56 PM   #5
Freeze's Avatar
As soon as you take the load off the engine at that speed, the tranny is going to shift into O/D and stay there. The new ZF tranny for 2012 should be much better than the Mercedes one we have.
Old 12-26-2011, 07:01 PM   #6
Blkram88's Avatar
The problem is at full throttle though, the engine bogs around 110 and stops accelerating and then the trans shifts at 4500-5000 which is way to soon
Old 12-26-2011, 07:46 PM   #7
I looked in the service manual and nothing really pop's out. It does say to make sure your fluid levels are correct and this is critical. I think I would service the transmission and see if that has an affect. Reset the PCM. Inputs are coming from input speed sensor, output speed sensor, TCM input, trans temp sensor. You could also check MAP and TPS voltages. There are several shift tables that are determined by temperature. Try OD on and off and see how it affects the shifts. Good luck...
Old 12-27-2011, 12:40 PM   #8
FAhemiST's Avatar
Its trying to tell you you shouldn't be going that fast.
11 White CC 4x4
Old 12-27-2011, 03:09 PM   #9
"Bob"
motorscooter's Avatar
Old 12-27-2011, 06:21 PM   #10
Blkram88's Avatar
Fuild levels are perfect did a TC about 2 months ago and topped it off a week ago today, thanks for looking in the service manual, wouldnt those sensor trip a CEL if they were wrong? Also now that you mention it i normally have tow/haul on but when this happened it was off.
