rev limiter - Hemi Truck Club
Old 08-03-2011, 03:59 PM   #1
i was curious how to increase the rev limiter. i have a superchips cortex programmer and i have the option to increase the rev limiter so i did that. but my concern is that it the rpms only go to 4000rpm. how do i get it to 5500 or 6000?
thebigdogg316 is offline   Reply With Quote
Old 08-03-2011, 03:59 PM   #2
Old 08-03-2011, 05:50 PM   #3
You referring to when its not under load (P/N)?
Old 08-03-2011, 06:06 PM   #4
HemiByrd's Avatar
What did you set it to, bigdogg? I have mine set to 6300 rpm. Like SLT8 said, in park or neutral the PCM will still limit it to around 4000 rpm.
Old 08-04-2011, 06:44 AM   #5
Will25990's Avatar
Only way to get it to do it in neutral is have a custume tune put on your truck. And HemiByrd how you like ti shifting at 6300?
2003 Dodge Ram 1500 Hemi. A few mods... 3865 Superchip 91 tune. 8.2 Taylor shorties. NGK 5306. Stock 3.92 gears. Falken tires on stock 20's. K&N FIPK Intake. American Thunder DOSS Exhaust. Sonnaxx. A/F ratio gauge. Srt10 gauge cluster Pillar. Pacesetter Lt's and y pipe. Magnaflow Cats. 1/4 mile 14.340 1/8 9.102 times for right now :). Lot more to come!!!
Will25990 is offline   Reply With Quote
Old 08-04-2011, 06:57 AM   #6
HemiByrd's Avatar
Actually I have the 1-2 shift set to 5950 and the 2-3 set to 5850. Just the limiter is set to 6300. My motor is not far removed from stock and the power drops a lot above 6000.
Old 08-04-2011, 12:06 PM   #7
i have my rev limiter set at 6300rpm.
Old 08-31-2011, 12:51 AM   #8
Will25990's Avatar
I have mine set at 6000
Old 12-11-2011, 09:47 AM   #9
Will25990's Avatar
Okay the only way the rev limiter works if you shift manually like hemibyrd said power drops at 6000 mine does to even with headers so when i race i leave in drive if you have sonnax you shouldnt lag at all to shift in next gear. Mines an 03 you really cant adjust shift points only if you manually shift.
