Questions on Timing Chain & Tensioner - Hemi Truck Club
Like Tree17Likes
Old 04-28-2019, 11:05 AM   #1
oldmanram's Avatar
Hi Guys,
So I'm waiting for my ATK 392 stroker short block to show up , and I have most of parts.... but I had a question on the timing chain/gears and tensioner . I've read a couple threads on here and other forums. There doesn't seem to be a consensus on which to use, I know chris had a little trouble getting his hughes timing set/key figured out (chris's 6.4 stroker build) , and I have heard that some tensioners are better than others . I am going to just be putting the cam in straight up , but an adjustable set may be nice for down the road in case I swap out to a bigger cam down the road and want to advance it.
What timing set are you guys using ? or recommend ?
What tensioner set are you guys using ? or recommend ?
I also remember reading that someone had trouble fitting a double roller on there motor , something about a threaded plug and clearance issues . ??
thank you in advance !!
Old 04-28-2019, 12:45 PM   #2
Checkout Rock Auto..
https://www.rockauto.com/en/catalog/...iming+set,5756
Old 04-28-2019, 06:57 PM   #3
If this is going to be a street driven truck. The stock 6.1 timing chain and 6.1 exhaust valve springs will be fine. If your adding much stronger springs for boost, then a performance timing chain would be a good investment.
Old 04-29-2019, 07:38 AM   #4
oldmanram's Avatar
Has anybody used the Melling 405 series timing set/tensioner ?
Has adjustable timing but just a single roller chain,
https://www.rockauto.com/en/moreinfo...1430807&jsn=15
Old 04-29-2019, 08:29 AM   #5
I like the link chains, they are strong!
Old 04-29-2019, 01:41 PM   #6
That should work good.
Old 04-29-2019, 04:02 PM   #7
Chris
YeahItsAHemi's Avatar
From my research the 6.1 set is the same as the 5.7, but it has a few more leafs in the tensioner pack to make it stronger.
Ghost03hemi and Redtruck-VA like this.
Tuned by Charged392
Old 04-29-2019, 05:33 PM   #8
I like the 6.1 oil pump too.
oldmanram likes this.
Old 04-29-2019, 08:18 PM   #9
oldmanram's Avatar
From what I have read
The 6.1 tensioner has 4 leafs and the 5.7 has 2 leafs but also
the tensioner material itself is different, with the 6.1 material SUPPOSEDLY stronger and less likely to groove as much.
Those are OEM tensioners , but what about the aftermarket stuff ,
How good are the tensioners on the aftermarket sets ?
Melling 40540 (single roller)
Manley 73205 or 73206 ? 73206 has thrust bearing (needed ?)
Howards 94332 (yaitsahemi) chime in
and not to mention
cloyes ?
comp cams ?
In my experience with auto parts
"You get what you pay for"
I'd rather overbuild than underbuild and have to do it again !!
Redtruck-VA likes this.
Old 04-29-2019, 08:25 PM   #10
oldmanram's Avatar
The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten -
ric3xrt likes this.
