question about fuel pressure reading - Hemi Truck Club
Like Tree7Likes
Old 11-28-2018, 03:40 PM   #1
Hello all.....
2004 Dodge ram 1500 5.7 HEMI 83k
diagnosing a p300 error.
the truck started running really rough, missing,would barely pull itself, and shacking to the point that it would die while running down the road. the only way to get it to start back up was to hold the gas peddle to the floor (i know it shouldn't make any difference it's fuel injected) There is also a strong fuel smell (flooding condition i assume, my LTFT are at -25 +/- 1 across B1 and B2) and that's not even with the motor running. Pulled injectors looking for leaks and they are all dry when i turn on the truck, checked with a paper towel(with key on), also put a pressure gauge on the fuel rail and when i turn on the truck it will get to 59PSI but as it sits there (with key on) it will start to drop down over time. no leaks from the injectors and can smell gas fumes.
I hit the pressure release button on the fuel gauge by accident and the pressure dropped (of course) but it didn't build back up. will it rebuild that pressure or does that only happen when the engine is running.
sorry, lots of info (it could even be considered ramblings). I know i missed something as im posting this in a hurried manner.
do i need to look at a new fuel pump?? p0300 is the only code i have right now. have also gotten p0430 (i think) catalytic converter efficiency bank 2 in the past
Ram50 is offline   Reply With Quote
Old 11-28-2018, 04:29 PM   #2
Old 11-28-2018, 05:08 PM   #3
thanks for the welcome.
update.,
got everything put back together and started the truck. running rough of course but the fuel pressure gauge bounces wildly when running, between 60 psi and 50 ish psi was really bouncing fast. does that point to a fuel pump or possible vacuum leak.
Old 11-28-2018, 06:52 PM   #4
Bouncing fuel pressure is most times a failing regulator in the pump at the tank it should stay pretty steady.
-25 is not a fuel starve issue thatís for sure. If both banks are reading -25 then you likely have a bad MAP sensor as thatís really the only sensor that can make the fuel go crazy rich. A shorted intake temp sensor can also do it but not likely. Do you access to a scanner of some sort to get some data of the idling engine and at 2,000 rpm
Old 11-28-2018, 07:35 PM   #5
yes i can pull some live data. but the motor is running so rough right now that i don't think i can get it to stay at a constant 2k rpm, I'll try in the morning.
The fuel regulator appears to be on the top of the fuel tank made as part of the fuel pump assembly. replacement one is 107.00 new fuel pump with regulator is 169.00 both will have to be ordered. may just get a whole new assembly just so that i know everything is new.
SUPER BEE likes this.
Old 11-29-2018, 03:06 AM   #6
Welcome back.
Keith will help you to get your truck straightened out.
Old 11-29-2018, 06:28 AM   #7
start out by getting some sensor readings or pictures of the scanner while truck is running and lets go from there.
Old 11-29-2018, 12:54 PM   #8
I had another MAP sensor so i put that in last night, so i imagine that the reading will have changed. I have another to try if need be. the way the truck is running has changed. Not as rough but there is still a miss or something. the wrong fuel pump came in this morning so i have to wait until 5 pm today for the replacement. Had was able to get some pictures of the scanner tool Live data, Ill post below. I also had the battery disconnected for a time lastnight. That may skew the reading some also
http://i1339.photobucket.com/albums/...psscegf0oz.jpg
Old 11-29-2018, 04:55 PM   #9
update:
The new fuel pump is in. The fluctuating fuel pressure is fixed. It sits at 64 PSI. (running at idle) now that that is done I can concentrate on the the rough running / miss in the truck. Looks like im (with this sites help) chipping away at it one issue at a time
While I'm waiting for the help/replies (thank you so much by the way) I going to do a compression test just to make sure that is all good. plus my oldest son is helping so Ill make him get the plugs in the back
Old 11-29-2018, 06:01 PM   #10
The rail pressure for a 05 is 58psi, 64psi is high but most likely can be compensated for by the pcm. I had a 03 which should be 48psi that compensated for 58psi for a few months but then couldn't and caused tuning issues. Keep a eye on the trims.
