Only 288hp at 5300 RPMs in 3rd??? - Hemi Truck Club
Old 11-09-2017, 08:27 AM   #1
Starchief_59's Avatar
I dynoed my truck a while back and it shifts out of 3rd at 5300 every time. It did 288hp and somewhere around 300 ft lbs.
In 2nd gear it would only do 235ish hp which he said isn't an accurate number (obviously) but it did show hp climbing all the way to around 5800 rpms.
How are yall keeping it in 3rd gear all the way throughout the RPMs? We dynoed about 12 or 15 hemi cars that same day and none had this problem
Mine is an 07 with an ATS trans, supposed to be a 3k stall, pacesetter long tubes, gutted cats, x piped and dumped, 4.56 gears, intake, diablo 93 octane tune and moes 87mm throttle body. I figured it would do about 315-325 hp.
I've heard diablo is having problems with trans tuning. Could this be part of it? I've never updated it and I heard that the update is what screwed up the tuning. My shift points are raised 1-2 and 2-3 and it shifts pretty hard.
Robert Lewis
1959 Pontiac Star Chief 4 Door Hard Top
2007 Dodge Ram Single Cab Long Bed - almost no options except posi and HEMI!
www.Pontiac-59.com
Old 11-09-2017, 08:37 AM   #2
I dont have personal experience in doing this, but I've heard it said that after it shifts to 3rd at wot over 5000rpm you can pull the lever back to 2nd and itll hold 3rd gear. Check it out, I never tried it nor need to using a 46rh trans.
Old 11-09-2017, 08:51 AM   #3
Believe you have to start the dyno run idling in first gear tire spinning, in drive, tow/haul off, Then to wot, pull down the shifted into 2nd when it goes into 2nd, then into drive and it will hold 3rd gear.
Keith(charged392) did it that way when he had a 545rfe in his truck I believe. Please correct me if I'm wrong Keith.
A floor shift would be easier to do that with.
You truck sounds good.
Old 11-09-2017, 08:53 AM   #4
Hhmmmmm I'll have to try that next time. I guess that makes sense. Thanks
Any guesses to HP on my turd?
Robert Lewis
www.Pontiac-59.com
Old 11-09-2017, 08:54 AM   #5
Damn, my tow haul button doesn't work. I need to fix that anyway. Thanks Stu
Robert Lewis
www.Pontiac-59.com
Old 11-09-2017, 08:57 AM   #6
How's the ATS trans working? Are you using the Copilot?
Old 11-09-2017, 10:01 AM   #7
Chris
YeahItsAHemi's Avatar
I’ve heard stock hemis dyno at ~280 hp. I️ hope you can get 315 or more
Tuned by Charged392
Old 11-09-2017, 10:10 AM   #8
Thats what I was thinking. The truck ran 14.81 100% stock. Best I've ran was 14.5 but never could get traction after the 4.56 gears. I havent ran it with the ATS trans, converter and throttle body. I know it's got a 13.9 in it. The truck runs killer
Robert Lewis
www.Pontiac-59.com
Old 11-09-2017, 10:41 AM   #9
https://youtu.be/cJTJhi6O1dc
My truck on the dyno. Start in second roll up to about 4500 hammer it shift to D and when it get a to 4700 pull it back to 2nd and it should hold third.
Option B is get a tune and I can set 1-2 2-3 shift points so it will hold third longer.
Old 11-09-2017, 10:45 AM   #10
Sweeeeet. I'll try that next time
Robert Lewis
www.Pontiac-59.com
