Oldmanram's 392 Stroker Build - Hemi Truck Club
Like Tree110Likes
Old 05-07-2019, 03:52 PM   #1
oldmanram's Avatar
Smile Oldmanram's 392 Stroker Build
So I am sitting here waiting for my motor to be delivered , since my original 2003 5.7 hemi only lasted till 253K miles .
The motor is the ATK SP97, A 392 cu in stroker
Specs Below:
Block: Seasoned OE Gen III Hemi 2003-2008
Bore/Stroke: 3.927 x 4.050
Displacement: 392 C.I.D.
Crankshaft: Scat 4340 Forged 4.050" Stroke Internally Balanced
Connecting Rods: Scat 4340 Forged H Beam 6.125" ARP 8740 Bolts
Pistons: Forged -2cc Flat Top
Piston Rings: Moly Rings
Compression Ratio: 81cc=9.9:1 /85cc=9.6:1/89cc=9.2:1(based off .028" gasket)
Camshaft Bearings: Installed & Clocked to OEM Position
Freeze Plugs: Installed & Sealed
Oil Galley Plugs: Installed & Sealed
I also had ARP Main Bolts installed
I'm going to use my 85cc heads and have them milled to get the compression to a little over 10:1
updates to follow
Old 05-07-2019, 04:48 PM   #2
Pretty sure you will like your new motor...
Old 05-07-2019, 07:32 PM   #3
oldmanram's Avatar
Well waited around and it FINALLY showed up !! WOOHOO
This is what ATK's crating looks like , not the greatest but adequate, the engines are protected in a thick plastic bag at least, and if have a concrete driveway you can get away with moving it around on a dolly like this .
Redtruck-VA and SUPER BEE like this.
Old 05-07-2019, 07:48 PM   #4
Good job!
Old 05-07-2019, 09:13 PM   #5
oldmanram's Avatar
Other items for the build :
arocketman and ric3xrt like this.
Old 05-07-2019, 09:20 PM   #6
oldmanram's Avatar
05037479AA 6.1L Fuel Injectors !
ric3xrt likes this.
Old 05-07-2019, 10:01 PM   #7
oldmanram's Avatar
I asked for the build specs to be included :
I received :
The Balancing info on the crank
ATK's break-in procedure , 2 pages worth , good info , all of which I know , but at my age it's that they have written so I don't forget something .
and some stickers (ATK) (Mahle) (Scat) ..... owwww ahhhh
It looks like the block has been decked (milled) but by how much ??
Old 05-07-2019, 10:29 PM   #8
oldmanram's Avatar
One the extra's that I requested was ARP Main Studs & cross bolts....
And being the trusting sole I am , I emailed them twice for confirmation that they were in fact using ARP main studs & cross bolts ..
Confirmed !!!!
I can see the ARP 12 point cross bolts
SUPER BEE likes this.
Old 05-08-2019, 02:00 AM   #9
oldmanram's Avatar
Pistons MAHLE
arocketman likes this.
Old 05-08-2019, 02:14 AM   #10
oldmanram's Avatar
and my cam came in tonight !!!
It's just a little bigger than a 6.1L cam ,
should be easy to tune , if needed
