Need help!! - Hemi Truck Club
Old 04-13-2016, 01:16 PM   #1
Need help!!
New here so I hope I'm doing this right. I've just put a 2008 5.7 in a 2007 body. During the swap I noticed the cam shaft position sensors are different (I installed a 260 comp camp with bee hive valve springs.) so I put the 2007 sensor in so I could plug it in. Now of course I get a p0016 code and my engine is in limp mode. WHERE DO I GO FROM HERE?!?
Saulshemi is offline   Reply With Quote
Old 04-13-2016, 03:12 PM   #2
Board of Directors-Bill
arocketman's Avatar
Give us some time to think this one over. Some one will give you a good answer.
05 QC
BLUE MAX
"Slightly Tweaked"
Just [email protected]
Old 04-13-2016, 03:17 PM   #3
Old 04-13-2016, 03:55 PM   #4
Ok that shiudnt matter it was all the same except for the mds option until 2008/9 I believe. That code is a correlation code meaning something is likely out of time. Your timing chain may be off a tooth I'm thinking here. The sensor has a diff plug but operates the same way as the 2008 the wheel is even the same on the cam.
Old 04-13-2016, 04:01 PM   #5
Welcome to the forum. Looking at tone ring count this what I found.
The stock 2008 and earlier 5.7 and 6.1 engines use the 32 tooth ring, while 2009 and later require a 58 tooth ring.
So you should be good using a 08 engine in a 07 body. I have read in the past that occasionally the cam sensor and crank sensor get out of sync and need a scan tool to re-sync. Also if a cam is installed off a tooth it can throw a code. Did you take pictures of your cam line-up?
Old 04-13-2016, 04:11 PM   #6
I didn't take a picture of my cam line up. I thought of this but it idles smooth and revs fine in park. May still be the problem though. Guess I'll be tearing the front off to double check. :cry2
Old 04-13-2016, 05:13 PM   #7
I often start second guessing what I did. So I take a picture to save myself an unnecessary tear down.
Old 04-13-2016, 05:15 PM   #8
Old 04-13-2016, 05:16 PM   #9
I think this is something I will start practicing
Old 04-13-2016, 05:18 PM   #10
Lots of guys on here have excellent tried and true advice .
