Melling Oils Pumps Compared - Hemi Truck Club
Like Tree4Likes
  • 4 Post By oldmanram
Old 05-02-2019, 09:07 PM   #1
oldmanram's Avatar
I thought I would pass this on for those a little confused by all the different
Melling Oil Pumps..... I was !! So I emailed Melling asking for some clarification on the different oil pumps they offer for the 5.7 and 6.1 Hemi engines . This is the response :
Gentlemen PLEASE : explain once and for all the differences between the Melling
M342: stock 5.7 pump
M362: same as the M342 with the exception of the bypass spring, the M362 has a higher bypass setting than the M342
M10342: performance version of the M342, standard volume high pressure pump, hard coat anodized body, will include 2 optional bypass springs.
M10342BR: same as the M10342 but has a billet steel rotor set.
I also asked for a recommendation :
I am building a street 392 stroker from a 5.7 Hemi , expecting to see 6300 rpm .What pump do you recommend ??
Answer: M10342, unless it will be supercharged, if so use the M10342BR
Old 05-03-2019, 04:09 PM   #2
Sounds about right to me.
Old 05-03-2019, 04:18 PM   #3
Good information!
Old 06-20-2019, 09:14 PM   #4
For what its worth...I've been running the Melling 10342 in my 5.7 based stroker (400ci) for several years. Pretty much 45 psi all the time.
Diablothunder is offline   Reply With Quote
