Madoyster2003 Dyno run 😈 - Hemi Truck Club
Old 06-18-2019, 05:40 PM   #1
Madoyster2003's Avatar
We I figured I'd update y'all on what's been going on with my truck! I've upped the compression, swapped out the throttle body for a 90mm bbk, new stainless 4" intake, Johnson lifters, and of course Keith tuned it.
What Ive got in the works is a 6 speed out of a Challenger and I'm going to keep my power adjustable pedals. Ohhh and a remote mount rear turbo.
332 hp to the wheels for those wondering
https://youtu.be/5zsy6HER3B8
Old 06-18-2019, 06:43 PM   #2
Did you dyno before doing all this I forget?
Old 06-18-2019, 07:01 PM   #3
I did it maxed out at 250 to the ground I think
Old 06-19-2019, 04:18 AM   #4
Well done, which Johnson lifters did you use? Curious if you have an opinion about them?
Old 06-19-2019, 04:56 PM   #5
I got the slow leak ones and my hemi tick is gone. As for anything else they work.
Old 06-19-2019, 05:44 PM   #6
I asked because we recently had a discussion about lifters.
https://www.hemitruckclub.com/forums...hts-30024.html
Old 06-20-2019, 10:02 AM   #7
Chris
YeahItsAHemi's Avatar
Is that with the comp 273 cam?
Tuned by Charged392
Old 06-25-2019, 04:35 PM   #8
Yes it is. I was running .075 gaskets but moved to .051. thinking about going thinner if the valves will clear
Old 08-06-2019, 05:16 PM   #9
ric3xrt's Avatar
Picked up 80Hp that's good, How is it running? did you get the 6 Speed in yet?
04 GTX...Under the Knife.
Old 08-07-2019, 06:25 PM   #10
Truck has been running great other then a front main seal leak. I figured while I was in the I might advance it 4 degrees and pick up some torque. As far as the 6 speed goes that's on hold. I've recently started a new side business fabricating and that's taken up a bunch of time.
