I have a problem - Hemi Truck Club
Like Tree16Likes
Old 10-02-2018, 04:13 PM   #1
chefred112's Avatar
I have a problem
Hey all...I have an issue that came up today...not sure when the symptoms started. Simply put, battery died out because alternator wasn't charging it, so it seems. I happen to be in the same parking lot as an autozone when my check gauges warning light came on and the gauge showing charging was all the way to the left. Had Autozone check battery, said it was good but needed charging, so I started truck and they said it wasn't getting any volts so we assumed alternator. Bought Alt and drove back to office where the battery totally ran out. Installed new alternator and had a fellow member come by and give it a jump. Started but the gauge didn't go all the way to middle and when I removed jumper cables the gauge went to the left again and drain out. Is there a voltage regulator on our trucks? thanks in advance fellas..
__________________________
-fast freddie- 392 hemi :)
Old 10-02-2018, 04:44 PM   #2
Mark G Senior Member
bada44's Avatar
As far as I know voltage is controlled in the PCM... But I may be wrong. this would be a good question for one of the true mechanics I'm sure one of them will chime in...
Please Donate today!
https://www.stbaldricks.org
I stand for the flag!
[email protected]
Old 10-02-2018, 04:50 PM   #3
Seems my first post didn't make it. The pcm provides a field voltage to regulate the output voltage. I believe I have read there is a work around for installing a external regulator.
Old 10-02-2018, 05:21 PM   #4
Here is a diagram.
Old 10-02-2018, 07:53 PM   #5
The alternator is controlled by the pcm to duty cycle the alternators output. Make sure the battery is good it can also cause the pcm to not charge. The pcm will run about a 35-55% duty cycle to the alternator.
Make sure you have battery voltage at the big wire on the alternator itself. If you have voltage there then make sure you have power on pin 1 of the alternator plug brown and white wire. If you have power here then your good so far. The next part is testing for pcm control by which you need a logic probe or a power probe. You will want to probe the pin 2 wire truck running and look for a pulsed ground signal. A test light for this will not work as it will simply create a ground and show you nothing or fry the pcm completely. The logic probe or power probe will simply show you what the wire is doing. If you have nothing happening on this wire then make sure every single fuse is good in the fuse box and also make sure no wires got melted anywhere that you can see.
Old 10-03-2018, 08:31 AM   #6
chefred112's Avatar
Thanks for all the info and advice my friends, im bringing a freshly charged battery to work to bring her home. I think my 1st step is to install an external regulator for now and then check the advice in last post..
Old 10-03-2018, 10:36 AM   #7
chefred112's Avatar
I have another problem that seems to be coincidental. Does the issue in any way affect powersteering? I can start the truck (still has enough juice as I charged it a little bit) but when I go to re-park it the steering is totally manual and I have to move and muscle the wheel at the same time. Maybe it's just me but it seems the belt is moving slower than usual at idle...clutch fan not engaged so it seems slow.
https://youtu.be/R78-GdHW8so
Old 10-03-2018, 10:37 AM   #8
chefred112's Avatar
I was going to drive it home on the battery but at this point I think I'll just AAA it.
Old 10-03-2018, 10:50 AM   #9
chefred112's Avatar
could my power steering pump go bad? its just coincidence that is happening at the same time...
Old 10-03-2018, 10:55 AM   #10
Sounds like something is dragging the belt slowing charging and pump down.
