how much can a 6.1 timing set handle? - Hemi Truck Club
Like Tree39Likes
Old 05-30-2019, 06:46 PM   #1
Randall
BeeFast's Avatar
How much horsepower can you throw at a 6.1 OEM timing set. Are there good alternatives?
Procharged P1Sc, Big valve P&P heads,HC lifters,Inertia Blower cam, Mopar long tubes with SS 3"true duals, Magnaflow hi-flow cats & Race mufflers, T56 manual swap with Centerforce DYAD clutch, Dana 60 with cryoed 4.56 gears, Caltracs, Flexalite & custom Injected Engineering dyno tune.
BeeFast is offline   Reply With Quote
Old 05-30-2019, 08:39 PM   #2
I am running a pretty much stock timing set for the most part to over 800 crank lol I know I should swap to a dual chain setup for safety
SUPER BEE and BeeFast like this.
Old 05-30-2019, 10:29 PM   #3
oldmanram's Avatar
Well I'm building a motor right now , and I'm going to use the Howard's Timing Set . As a matter of fact it just arrived today . I can send you some photo's of the ACTUAL item.
BeeFast likes this.
Old 05-31-2019, 09:38 AM   #4
Do NOT buy the double roller setups from Manley, Engine Pro, or SA Gear. SA Gear actually makes it for all of them. They will not hold up for very long. Chain stretches something terrible, reluctor wheel will come off, and various issues The stock set will handle a lot.
Howards has good stuff so I would love to see some pics oldmanram. I'm curious who makes the chain for them. IWIS is one of the best brand chains you can get. Curious if they have a torrington bearing on the cam gear and if it's adjustable as well. Please post details and cost. Thanks
Redtruck-VA and BeeFast like this.
GFB Performance is offline   Reply With Quote
Old 05-31-2019, 09:59 AM   #5
Chris
YeahItsAHemi's Avatar
I have the Howard’s double roller. It’s about $170
BeeFast likes this.
Tuned by Charged392
Old 05-31-2019, 10:02 AM   #6
I have not used the Howards unit. I hope it's not made by SA Gear. Howards usually has high quality parts but they don't actually make everything so hopefully they made this one
Old 05-31-2019, 10:05 AM   #7
Tyler
TYSENUS's Avatar
I'm running a 6.1 set, I have never heard of any issues with them.
BeeFast likes this.
Mods:
Old 05-31-2019, 11:14 AM   #8
The ones I've used have been double roller and oem link. For pure strength I would think oem link would be hard to beat.
BeeFast likes this.
Old 06-01-2019, 12:13 AM   #9
oldmanram's Avatar
I'm trying to upload photos ,
Photo''s of Howards Timing Set , I can only post 4 photo's per reply so .......
To me, it MAY be the SA Gear set .........
I can make out that it IS a ROLON chain
I'll post some close ups next
BeeFast likes this.
Old 06-01-2019, 12:18 AM   #10
oldmanram's Avatar
close ups
Question :
Are there ANY double rollers that use GOOD chains ?
What about the Comp Cams Timing Set ?
BeeFast likes this.
