Head Torque and Sequence!!! - Hemi Truck Club
Old 01-19-2009, 06:34 AM   #1
brand_x_racing's Avatar
Need the Head torque specs and sequence, Havent found anything anywhere on this, diagram would be greatly appreciated! Would be deff good to have here for some of us without a chiltons!
2011 Dodge Ram CC hemi mineral grey, 22 KMC slides
1956 Dodge c3 pickup, 1/2 ton , 318, disc brake conversion, 904 trans, 791 rear axle, 15 gallon schlitz keg for gas and mini Full custom audio system, 1960 Cushmas Eagle, full chopper, 16hp v-twin, raked to 40 degrees, custom cut fenders and alum accessories, custom silver with blue flames. 1954 Buick Super 4dr Lido green and white, nailhead powered, 1941 Chevy fenderless truck project, 1958 ford fairlane 5.0 powered,
www.stubbsrodandcustom.com
"Hey where da white women at"
Old 01-19-2009, 06:48 AM   #2
JAMESD's Avatar
INSTALLATION
1 - HEAD GASKET
2 - OIL HOLES pic 3
Clean all surfaces of cylinder block and cylinder heads.
Clean cylinder block front and rear gasket surfaces using a suitable solvent.
CAUTION: The head gaskets (1) are not interchangeable between left and right sides. They are marked L and R to indicate left and right sides.
CAUTION: The head gaskets (1) are marked TOP to indicate which side goes up.
1 - CYLINDER HEAD COVER
2 - COVER GASKET
3 - FASTENERS
4 - CYLINDER HEAD
5 - HEAD GASKET pic 4
Position new cylinder head gaskets (5) onto the cylinder block.
Position cylinder heads (4) onto head gaskets (5) and cylinder block.
Tighten the cylinder head bolts in three steps using the sequence provided :
Step 1 Snug tighten M12 cylinder head bolts, in sequence, to 34 Nm (25 ft. lbs.) and M8 bolts to 20 Nm (15 ft. lbs.) torque.
Step 2 Tighten M12 cylinder head bolts, in sequence, to 54 Nm (40 ft. lbs.) and verify M8 bolts to 20 Nm (15 ft. lbs.) torque..
Step 3 Turn M12 cylinder head bolts, in sequence, 90 degrees and tighten M8 bolts to 34 Nm (25 ft. lbs.) torque.
1 - PUSHROD RETAINING PLATE FASTENER
2 - PUSHROD HOLDER pic 1
Install push rods and rocker arm assemblies in their original position, using pushrod retaining plate (1) special tool# 9070. (Refer to 9 - ENGINE/CYLINDER HEAD/ROCKER ARM / ADJUSTER ASSY - INSTALLATION) .
Install the intake manifold and throttle body assembly(Refer to 9 - ENGINE/MANIFOLDS/INTAKE MANIFOLD - INSTALLATION).
If required, adjust spark plugs to specifications. Install the plugs.
Connect the heater hoses.
Install the fuel supply line.
Install the power steering pump.
Install the drive belt(Refer to 7 - COOLING/ACCESSORY DRIVE/DRIVE BELTS - INSTALLATION) .
2 - COVER GASKET
3 - FASTENERS
4 - CYLINDER HEAD
Install cylinder head covers (1)(Refer to 9 - ENGINE/CYLINDER HEAD/CYLINDER HEAD COVER(S) - INSTALLATION) .
Connect the evaporation control system.
Install the air cleaner(Refer to 9 - ENGINE/AIR INTAKE SYSTEM - INSTALLATION) .
Fill cooling system(Refer to 7 - COOLING - STANDARD PROCEDURE) .
Connect the negative cable to the battery.
Start engine check for leaks.
Sales Thompson Chrysler Jeep Dodge 410-679-1400 [email protected], 03 Ram 4x2 reg cab HEMI,hedman hedders, 4.56 gears, Superchips programer, ported TB, 305/50/20's (rear), 285/50/20'S (front)custom k&n air intake, magna flow, lowered, bed rug, t cover, front air dam, HEMI billboard (painted on), 6.1 cam (srt-8), 6.1 heads(srt-8), Custom hood, Daytona Wing (cut down), 06 fuel pump, Tayor shorty wires, Xplode amp and 10" sub, Transgo shift kit, TCI converter, more to come. The Boss (wife) has a Dodge too. Her ride is a 2010 Dodge Nitro
JAMESD is offline   Reply With Quote
Old 01-19-2009, 06:48 AM   #3
JAMESD's Avatar
1
Old 01-19-2009, 06:49 AM   #4
JAMESD's Avatar
2
Old 01-19-2009, 06:49 AM   #5
JAMESD's Avatar
3
Old 01-19-2009, 06:50 AM   #6
JAMESD's Avatar
4
Old 01-19-2009, 07:11 AM   #7
I needed that soo much, and think others who might have to open the Hemi up some more could use it too!
Thanks so much!
Old 01-19-2009, 07:14 AM   #8
JAMESD's Avatar
Anytime
Old 01-19-2009, 08:37 AM   #9
Great info James - thanks
Old 01-19-2009, 09:18 AM   #10
