Gathering of parts has started early - Hemi Truck Club
Old 10-29-2011, 10:20 PM   #1
i usually order a few parts before returning stateside each year in preparation for my moding season. I got ahead of myself this year and have started gathering early. So far I have a sharadon stage III valve body. 20% under drive pulley, Crower adjustable timing chain, HSW TB injection plate (meth inj)and a new Snow Meth/water stage I boost kit. I already have a Granatelli dual window switch installed and plan to trigger the Meth inject using inputs from vacum, rpm and throttle position voltage. This should control the window of operation to a specific range. Future modes include heads/intake running relatively high comprssion. sorry I got a little excited and have the need to share.
Old 10-29-2011, 10:20 PM   #2
Old 10-30-2011, 04:00 PM   #3
Originally posted by Redtruck-VA:
HSW TB injection plate (meth inj)and a new Snow Meth/water stage I boost kit. running relatively high comprssion.
Hummmmm............
Old 10-31-2011, 03:53 AM   #4
ROLLING THUNDER's Avatar
We understand.
It's an addiction with no 12 point program
ROLLING THUNDER is online now   Reply With Quote
Old 10-31-2011, 02:28 PM   #5
Are you adding boost or just higher compression pistons and or heads Greg? Expected static CR? Street use?
Old 10-31-2011, 02:39 PM   #6
5SpeedHemi's Avatar
what brand underdrive did u get
Old 11-02-2011, 09:58 PM   #7
I lost track of this thread, my bad. I'm thinking 6.1 heads, milled .020 on a stock 5.7 block. Should give close to 11.5 CR. This is all street use with occassional trip to the strip. The HSW TB plate has dual feed and is designed for nitrous. I'm planning on using one feed for methanol and if I have enough fuel control I may plumb the other feed with a lite nitrous shot. Also may drop the SC tuner and use B&G for the baseline tune stacked with the PSC1 to fine tune everthing. The underdrive hub is the ProSport Model.
Old 11-03-2011, 03:11 AM   #8
Are you going to re-gap your stock compression rings?
Old 11-03-2011, 03:46 AM   #9
Do not plan on it. Figure i'll break something at some point, then will figure what to do from there.
Old 11-04-2011, 03:54 AM   #10
David
ATXHEMI's Avatar
That sound like an expensive way to find your weak spots....
