fuel pressure readings. - Hemi Truck Club
Old 03-17-2011, 03:46 PM   #1
schemigrunt's Avatar
hey guys I figured i would share this info for you just incase anyone has to do a fuel pressure check on their truck. accoarding to alldata the factory fuel pressure with key on engine off pump engage is 58 psi +/- 2psi. the fuel pressure at idle with the engine running should be accoarding to alldata is 60psi +/- 2psi.
schemigrunt is offline   Reply With Quote
Old 03-17-2011, 04:36 PM   #2
The 03's, are some what less.
Old 03-17-2011, 05:32 PM   #3
Correct, '03s are 48 psi factory. Mine's thirsty so it idles at 68 psi and goes up from there.
Old 03-17-2011, 10:10 PM   #4
good input jay. i was going off the alldata and sometimes they put incorrect info up. i double check for the 05 against the chrsyler dealer service information.
Old 03-18-2011, 07:47 PM   #5
What kind of fuel pump or pumps, are you running FrostKing?
I'm hoping to keep both of my 03 fuel pumps at 50 to 58psi. If my setup works, I'll post up the mod on the forum.
Old 03-19-2011, 12:04 AM   #6
I am using an'03 and '04 pump together in my original '03 basket. They are setup as a return style system and no longer use the stock pressure regulator or fuel lines.
Old 03-20-2011, 08:09 PM   #7
Hummm... Did you have problems with it?
Here's my setup. These are both new 03 fuel pumps. This message has been edited. Last edited by: Ghost03hemi, document.write(''+ myTimeZone('Sun, 20 Mar 2011 18:42:17 GMT-0700', '20 March 2011 09:42 PM')+''); 20 March 2011 09:42 PM
Old 03-20-2011, 08:12 PM   #8
It fit very well.
Old 03-20-2011, 08:13 PM   #9
And the regulators.
Old 03-20-2011, 08:24 PM   #10
I will have another OEM fuel line supplying fuel to the passenger side fuel rail.
I'm waiting on some s/s crimp clamps to come it for the stock plastic fuel pump hoses. Once there here, the assembly will be installed.
