early 5,7L block(2003-2008) max stroke? - Hemi Truck Club
Like Tree1Likes
Old 06-05-2019, 05:20 AM   #1
Rebuilding a early 5,7l hemi engine and found a K1 crankshaft with 4.080” stroke but unsure if it fits in the early 5,7l blocks?
Davey is offline   Reply With Quote
Old 06-05-2019, 06:02 AM   #2
That much stroke make be an issue and won’t really like the higher rpm ranges for safety
Old 06-05-2019, 10:01 AM   #3
at 7000rpm its still under 25m/s piston speed(24,18m/s = 79.333333fps), im ok with that rod ratio goes down to 1.5 ish thou... but even with a 3.795" stroke its 1.61.
Old 06-05-2019, 10:10 AM   #4
send it then lol. i turn my 392 to 7500 sometimes issue free but its only 4.050
Old 06-05-2019, 10:20 AM   #5
Tyler
TYSENUS's Avatar
I'm running the K1 4.080 crank but have never spun it above 6500. I bought it from Wiseco as a kit with pistons and rods.
Mods:
Old 06-05-2019, 10:25 AM   #6
so it do fit the 5,7l block then, neat!
the follow-up question is if the OEM chain is the most durable or if theres any stronger?
Old 06-05-2019, 10:31 AM   #7
Just had this discussion this morning with my engine builder. Our conclusion is oem is the strongest. If the cam needs adjusting you can use chevy offset bushings.
ric3xrt likes this.
Old 06-05-2019, 10:35 AM   #8
Awesome! Thanks guys!
Old 08-06-2019, 05:27 PM   #9
ric3xrt's Avatar
4.25 Cranks will fit also with some work, the bad thing is the last Oil drain back on the passenger side the passage that joins it to the 2nd to last has to be ground for clearance to the point that you break it open , you have 3 options one is Block it at the head, 2nd is to tap a line off it and run it to the pan, 3rd is to "tube" it which restricts oil flow.
04 GTX...Under the Knife.
Old 08-08-2019, 02:56 AM   #10
4.250 stroke in a 5.7 3.917 to 3.947 bore. Yikes!
