Cometic most gasket mods - Hemi Truck Club
Like Tree3Likes
Old 11-30-2018, 01:52 PM   #1
Madoyster2003's Avatar
So I've been thinking about doing this for a little bit now. I'm currently running 0.075 thick head gaskets and was going to "trim" the thickness down a bit. Basically the gaskets are made from 3 thin pieces of metal and 2 thick pieces. If I remove one thin and one thick piece then I should get a compression ratio around 10.5ish lol. Keep in mind this is all pending that I clears the 6.1 heads and the 273 xfi cam. I was going to do a dry run with some clay on the piston coating the clay with some oil. Hopefully this experiment will put to rest how thin of a gasket you can use when combining a stock 5.7 block/internals with 6.1 heads. Any thoughts?
Old 11-30-2018, 09:09 PM   #2
You wonít be able to take them apart like that you will need to get a thinner set of gaskets if you wanna do this. The gaskets have a sealer on the top and bottom not on the inside so if you remove the top or bottom it will leak.
Old 11-30-2018, 09:21 PM   #3
So I can't just drill the rivets, take them apart, clean them, spray copper on them and be good to go? Maybe I got lucky but I thought I had a blown gasket and did this. Motor has been strong for 5k miles. I just want to know exactly how think of a gasket I could use before getting into trouble. Compression or valve clearance.
Old 11-30-2018, 09:25 PM   #4
You can reuse the gaskets complete and spray like you did issue free you just canít use pieces of them all three pieces need to be there.
ric3xrt likes this.
Old 11-30-2018, 11:53 PM   #5
Dang it so much for this free experiment. Well there is one good thing that came from all this. The head gaskets that I'm using are 0.075" but I'm using the stock 6.1 pushrods. This leaves 0.046" gap. I think this would explain my less then spectacular Dyno results on the stock cam.
ric3xrt likes this.
Old 12-01-2018, 01:02 AM   #6
Sucks I can't turn that 5 layer into a 3 layer
Old 12-01-2018, 08:23 AM   #7
ric3xrt's Avatar
Taco Bell frowns on that...Ö
.051 is the tightest I've used with the 6.1 cam, the 273 cam I can't comment on. never used one in a stock 5.7 short block with 6.1 heads.
04 GTX...Under the Knife.
Old 12-01-2018, 05:48 PM   #8
Someone on this site has done the 6.1 intake, 6.1 heads and the 273 cam with no problems. I just can't find it. Was it SatinPumpkin or some name like that???
Old 12-01-2018, 07:22 PM   #9
That was me 😂😂 and I have 8.5k miles on the setup. Works but I want more lol
YeahItsAHemi likes this.
Old 12-01-2018, 07:36 PM   #10
Chris
YeahItsAHemi's Avatar
Tuned by Charged392
