Check engine light came on again - Hemi Truck Club
Old 02-06-2017, 07:13 PM   #1
Ariel
RAM4's Avatar
So a month ago while I was moving to my new place my check engine light came on. When I checked it the codes they were p0158 o2 circuit high voltage bank 2 sensor 2, p0700 trans control system, p0562 system voltage low, p0868 trans fluid pressure low. I cleared the codes and checked the trans fluid and it was full. I had the battery tested and I was told the battery was good but my cranking amps were low. So I hooked it up to the charger and charged it up. No check engine light.
Today I just ran to the store and on the way back I was at the light where I end up racing an xterra, from the light this guy was side by side with me and I couldn't shake him. Something's got to be up. As I turn away to head home check engine light came on. I checked it when I got home and here are the codes p0058 HO2S heater cont.., p0158 o2 circuit high voltage bank 2 sensor 2, p0700 trans control, p0157 o2 circuit low voltage bank 2 sensor 2, p0562 system voltage low. Thats all of them. I cleared it and haven't driven it seance. What do you guys think?
Old 02-06-2017, 07:31 PM   #2
Ariel
RAM4's Avatar
Another thing I forgot to add. A couple weeks back I stepped on it from a dig and i felt the truck hesitate and studder through the entire time I had my foot on it..
Old 02-06-2017, 08:16 PM   #3
Uh oh say it isn't so. The p0700 is just what the pcm is seeing next time you scan it see what the tcm reads also there is likely an issue going on there sir. Not at all concerned with the 02 codes but that 700 means something's up.
Old 02-06-2017, 08:28 PM   #4
Ariel
RAM4's Avatar
I just checked the pics I took of the scan. The tcm code was the p0562 system voltage low.
Sucks this is horrible timing for my truck to go down. I might de-mod and sell if the issues going to require a new trans.
Old 02-06-2017, 08:48 PM   #5
Anytime you have a sensor high voltage it generally means you have a open sensor, maybe a o2s heater in your case. Low voltage in this case is 5vdc. This voltage is used by sensors, particularly in your case transmission line pressure circuit. I look at grounds and electrical plugs. Charge the battery overnight and then if the dtc reappears a few days later, then replace the battery. The 0700 code is bad juju (slipping clutches)... you can use a scanner and determine the health of your trans. Good luck..
Old 02-07-2017, 02:34 PM   #6
Ariel
RAM4's Avatar
What could make the o2s go bad? I've replaced them both within the last couple years? I don't drive the truck a whole lot and I have them tuned out. Either way I guess it's the least of the issues. I just turned the truck on and the check engine line comes on right away, same codes. This really sucks.
Old 02-07-2017, 03:43 PM   #7
Remove the line pressure booster if you have one and see if anything changes.
Old 02-08-2017, 04:42 PM   #8
Ariel
RAM4's Avatar
Just tried removing the line booster and clearing the codes. I started it up and light came on right away. Same codes.. Do you think I'm looking at most likely internal issue?
Old 02-08-2017, 05:12 PM   #9
Old 02-08-2017, 05:25 PM   #10
When was the last time the filters and trans fluid was changed?
