cam shopping. - Hemi Truck Club
Old 01-17-2016, 02:33 PM   #1
knightmoves's Avatar
cam shopping.
Got a question guys! I have been looking for piston to valve clearance for my 06 5.7 hemi. I need this because I am looking at camshafts for Grace and looking at what I can or can't do. any one know what the clearance is? Also are there any compression helping head gaskets available? In dealing with other motors there are different head gaskets that are thinner than others and help raise the compression just a little.
Better to be silent and thought a fool than to open your mouth and remove all doubt!!
knightmoves is offline   Reply With Quote
Old 01-18-2016, 06:15 PM   #2
Most of the cams out there are simple install setups unless you go crazy like I want to do. You shoudnt be running into clearnace issues without a crazy cam. There are thicker gaskets to help lower compression if need be too.
Old 01-30-2016, 12:00 AM   #3
jmgak47's Avatar
I can tell you what will clear safely or not.
Jay
2014 RAM 1500 Express QC 2wd Hemi
5.7 Stock Block
1/4 - 12.18 @ 110.15 NA
1/8 - 7.74 @ 89.06 NA
426 Stroker
1/8 - 7.16 @ 95.79 NA
jmgak47 is offline   Reply With Quote
Old 01-30-2016, 03:06 AM   #4
Jay
LOL OK, tell me!
Old 01-30-2016, 12:15 PM   #5
Jay, what spec's do you recommend for a boost cam? 10 psi, 3000+ stall, 90mm TB, BV, 10:! cr, open LT, 4:10-4:56, 30" tires... Curious to see what you suggest...
Old 02-01-2016, 12:56 PM   #6
jmgak47's Avatar
Stock cubed 5.7? Raised compression just from milled heads? .020?
3000+ is it 3000 or higher? 11"?
ProCharged?
What year computer?
5.7 Stock Block
426 Stroker
Old 02-01-2016, 12:57 PM   #7
jmgak47's Avatar
Originally Posted by knightmoves View Post
LOL OK, tell me!
Depends are what your wanting to accomplish. And what lobes we use, p2v clearance varies greatly even with the same ICL, LSA and .050 duration.
5.7 Stock Block
426 Stroker
Old 02-01-2016, 01:55 PM   #8
ProCharged?
What year computer?
5.7 stock block
Heads milled ,020
Loose 3000 stall
NOVI 1200
05 manual trans pcm
Old 02-01-2016, 03:30 PM   #9
jmgak47's Avatar
Something along these lines.
215/226 .586/.581 116+4
5.7 Stock Block
426 Stroker
Old 02-01-2016, 03:40 PM   #10
Thanks, that is very close to what I had in mind...
218/228 .585/.595 with lsa 114 to 117 whatever the lobes would allow.
