Cam phaser - Hemi Truck Club
Old 09-11-2017, 07:50 AM   #1
Josh.vreeland's Avatar
Cam phaser
Hey guys. Just had top end rebuilt on 2013 ram. (3019.73$ ) I drive it back home. Battery very week and I go ahead replace it. Check engine light came on. Went back to mech that rebuilt top end. He's saying the code is cam phaser failure. Need some input on wtf is a cam and phaser and should this have been replaced during top end rebuild. ( my lifter roller froze up and sheared cam lobe #1 cylinder is what caused the top end rebuild )
Josh.vreeland is offline   Reply With Quote
Old 09-11-2017, 11:49 AM   #2
Im going to say no, its normally not messed with doing a top end. The cam sensor is located on the fro t cover passenger side in a recess. It is held with a 10mm bolt. I usually remove the bolt and wiggle the plug until the sensor comes out. Then disconnect the electrical plug. Of course care must be taken not to break the plug by pulling on it. Look at the face of it and see if there is any physical damage. The cam sensor controls the sequential injector firing and identifies knock cylinder location. If it has physical damage then it hit it's tone ring which is the top gear of the timing chain which was removed when the cam was replaced.
Old 09-11-2017, 01:30 PM   #3
ric3xrt's Avatar
The Cam phaser is what allows the VVT system work.
this is about the best video I can find right now.
Short answer is your mechanic had to remove the phaser system to replace your camshaft since you cam was wiped , he should of replaced the Phaser , because who knows what could of wound up in the unit.
this video is also a good one to watch...I'm not implying you need to delete the system, but I think this will help you understand what it does.
Old 09-11-2017, 01:58 PM   #4
Obviously I'm not knowledgeable about the "cam phaser" and spoke of the cam sensor so please disregard my previous post. Thanks Rick for getting the correct information out. Now I'll go back to my cave.....
Old 09-11-2017, 03:54 PM   #5
What was the code you got? This could be a simple wrong oil used code.
Old 09-11-2017, 04:22 PM   #6
I didn't ask for the code. Went to pick up the truck this afternoon and he printed a list of possibilities of reason why the code he had was thrown. He checked out the engine before test driving. He cleaned the sensor. Drained a tad bit of oil to check for debri . All good . One of the reasons was engine needed to be ran for a few miles ( break in) I took it home today. No lights and engine runs pretty good. Only thing noticing now is truck is super sensitive to steer adjustments while in motion . I'll mention this to tech when we look over engine once again in the morning . I'll ask for a print out of code as well.
Old 09-11-2017, 06:06 PM   #7
Yeah need to know the code please
Old 09-12-2017, 06:35 AM   #8
ric3xrt's Avatar
Is the WIFI better in there?
What your behind the curve on in cam phase/VVT you more than make up for in every other aspect of these trucks.
my guy feeling is the code was thrown because the PCM needs to relearn.
Old 09-12-2017, 07:00 AM   #9
He did a relearn on the pcm. Had it all day yesterday . Dropped son off at school. Went by mech and was good. Left and 1/2 mile away code threw and kicked me out overdrive . Left truck with tech
Old 09-13-2017, 02:26 PM   #10
The codes are P000B and P0016
