Calculating compression? - Hemi Truck Club
Old 01-10-2017, 02:54 PM   #1
When using the 05 84cc heads milled .030" what is the chamber volume? Trying to determine the dish the piston needs for 9:1 cr.
Any help is appreciated...
Old 01-10-2017, 04:51 PM   #2
Are the heads off? Might need to measure the volume with oil minus the amount being milled off for an accurate number.
Sold: 2003 Dodge Ram 1500
Old 01-10-2017, 04:53 PM   #3
No, the heads are on the block....
Old 01-16-2017, 07:45 AM   #4
That's a good ? If I new that I would know my compression ratio to the T
Old 01-16-2017, 11:03 AM   #5
ric3xrt's Avatar
Not sure if this will help you but they have some great calculation calculators over on Wallace's site.
Milling Calculator
Old 01-17-2017, 03:08 AM   #6
You have to have the correct stock engine specs first.
Old 01-17-2017, 04:29 AM   #7
ric3xrt's Avatar
there are few hemi gurus on Moparts maybe one of those guys can help you... with out actually measuring the heads after looking at the 04 heads I have here, it looks like a .03 mill would put you right in to the quench area.
Old 01-17-2017, 05:33 AM   #8
Unmodified 03 heads should be 84.5 cc. These are advertised as 9.5:1cr. Using .030 stock head gasket. I've been told .035 equals .5 compression point. So milled .030 using a .030 gasket should be 9:1cr with a stock 2cc dome piston. Using a -2cc piston with a .030 gasket should be 8:5cr. Or a flat top piston using a .030 gasket is 9:1cr. That's the rough combinations I have come up with using 2cc or .035 as .5cr... will have to be measured for an exact cr.
Old 01-20-2017, 09:26 PM   #9
JustHemi's Avatar
Just so I can see this in my head. So milling out a head and smoothing out the quench areas lowers your compression ratio because you have a greater volume of air left over at the end of the compression stroke therefore lowering the ratio of initial volume and ending volume? Am I understanding that right?
Amsoil Dealer (Greenwood, IN)
www.lubedealer.com/indyoilguy
Ph#: 317-383-6061
Many mods to come....hehehe.
Old 01-20-2017, 11:10 PM   #10
Milling a head is same as some folks call decking or planning. It only removes material from the flat mounting surface. But milling a head reduces chamber size which does rise the compression.
