Balancer - Hemi Truck Club
Like Tree2Likes
Old 08-19-2018, 04:34 PM   #1
biggnnn10's Avatar
Balancer
Ok Im almost ready to pop off the 392 Hopefullly last question.
With the eagle kit the Crank has a keyway. Has everyone cut there balancer or is there a balancer out there that has a keyway built into it????????
Rick Hart
biggnnn10 is offline   Reply With Quote
Old 08-19-2018, 04:58 PM   #2
The ATI balancer has a key way in it but I don’t use the key way I pinned my crank for the blower since I had already installed my front cover. My crank has a key way slot but I don’t use it either
Redtruck-VA likes this.
Old 08-19-2018, 05:52 PM   #3
I use a cog belt and the ATI balancer and it's keyway.
Old 08-20-2018, 05:30 AM   #4
ric3xrt's Avatar
for me, aftermarket crank after market Balancer.
04 GTX...Under the Knife.
Old 08-21-2018, 06:54 AM   #5
ric3xrt's Avatar
Did you get this rotating assembly balanced ? or are you using it as is?
Old 08-21-2018, 03:17 PM   #6
biggnnn10's Avatar
Yes it is all balanced and It had a keyway and I put the stock key in it. Now I just need a balancer I have poped it off just to here it run for a second but am a balancer away from being completely done with the stroker build.......
Old 08-21-2018, 07:53 PM   #7
biggnnn10's Avatar
ok I bought a ATI 918433 balancer. Any tips to how to install this dam thing. The eagle crank bolt threads are too deep for the install stud to screw into. the Stock bolt is too short to reach to help which even if it did you can not install with stock bolt without stripping the hole..
Did anyone have to have there ATI honed out to fit Mine goes on about an inch and then stops.
Or is there some trick to installing this damper because I'm all out of thoughts.
Old 08-21-2018, 08:11 PM   #8
I made a install bolt long enough to screw all the way in and then have a washer with a bearing, using a nut to pull it on. I also had Arrington hone the damper. I have had mine on and of a couple of times.
Old 08-21-2018, 08:39 PM   #9
Measure your crank and the balancer make sure the press for is not to much mine had to be opened up a good bit to fit correctly.
Old 08-22-2018, 05:42 PM   #10
biggnnn10's Avatar
yup I am going to machine shop tomorrow to have it honed out
