Anyone running a Crower Cam ? - Hemi Truck Club
Old 07-12-2017, 10:56 PM   #1
oldmanram's Avatar
Hi Guys,
I was just curious if anyone has run the Crower cams in your truck and what you thought of it ? In particular the 33491, 33492 or 33493 camshafts . Anyone ??
thank you for your input
Old 07-13-2017, 03:12 AM   #2
Crower grinds a lot of the cams for the industry. Generally with a crower grind, 6.1 push rods. If the lift is less than .560" 6.1 valve spring (16 exh). If higher choose the appropiate spring to do the job. With the 03 pcm you will find the wider lsa tune better.(114-116). The 03 pcm did well using a crazy spartan cam. You will have to look up the spec. But it was around 212/214 114lsa. Later i used a PPP 6.1 track cam. I think it was around 218/223 114 lsa .560 lift. It was difficult to tune with the 03 pcm. It used 6.1 push rods and i believe could be run on 6.1 springs but i used upgraded springs with it. I would say generally speaking start with a torque grind like the crazy spartan and go from there.
Old 03-27-2018, 09:02 PM   #3
oldmanram's Avatar
Nobody else running a crower grind ?
or have experience with them ?
This includes any of you stroker guys !!
Old 03-28-2018, 01:38 PM   #4
Chris
YeahItsAHemi's Avatar
Inertia has Crower grind their cams. I called Crower first and they spec’d a cam, then I called Inertia and Stu spec’d a cam that was much bigger. I think Stu knows these Hemi’s better then Crower does, that’s my opinion
Tuned by Charged392
