6.1 Rotating Assembly, Fuel Supply, Questions. - Hemi Truck Club
Like Tree7Likes
Old 09-08-2018, 08:30 PM   #1
This is all to work with my 84/75 Turbo Mega Cab
Rotating Assembly:
Normally I'd go thru SummitRacing.com but I don't see
anything for 6.1 RAs, so what are some good sites that
I can go to for Crank, Rods, n Piston Kit (Forged Parts)?
Fuel Supply:
Currently I have a Stock 5.7 Hemi (it will stay stock), In
time I will swap in a SRT8 6.1 (Lil bigger cam, 10:1 Comp
Maybe .30 Over). What Injectors n Pump will work for both
engine set-ups. I want to buy just 1 set of Injectors n Pump.
Rob Pod is offline   Reply With Quote
Old 09-09-2018, 05:48 AM   #2
ric3xrt's Avatar
Complete rotating assembly for a 6.1 Block , all you'll find is stroker kits
405 HEMI 6.1L Based Stroker Kits by Modern Muscle Performance
https://www.cnc-motorsports.com/call...rankshaft.html
There are afew more places but these are the two that came to mind
Stock stroke Crank, Ebay is your only real choice right now, they pop up in the $350-600 range about once a month.
Alternative stockish stroke is Molnar ( MOLNAR TECHNOLOGIES )
has a 3.59 NHRA crank (345-3593JB6F ) it'll set you back $960+ I just Dynoed a 372 (4065X3.59) 6.1 last weekend with the 359 crank.... , it's an RPM freak.
rods and Pistons can be found in the usual places.
Redtruck-VA likes this.
04 GTX...Under the Knife.
Old 09-09-2018, 06:37 AM   #3
Chris
YeahItsAHemi's Avatar
I’ve seen Inertia Motorsports has an option to buy a refurbished 6.1 stock crank, but I’m sure that depends on availability. It’s worth a call there, Stu’s a good guy to talk to about the hemis. Other then that, keep your eyes peeled on classifieds on Facebook swap meet pages, LX Forums. Luck is gonna play a big part in that. Also Stu at Inertia can put together a 360ish cc forged stroker combo with a 6.4 crank for about $2200, I’d highly recommend a conversation with him, I got my stroker cam through him
Tuned by Charged392
Old 09-09-2018, 06:42 AM   #4
ric3xrt's Avatar
I keep forgetting about Inertia Motorsports
Old 09-09-2018, 12:56 PM   #5
Above I mentioned possibly .30"
over, I'm not gonna do a stroker.
It's half of the reason I'm doing a
6.1, cause it's like a doing Stroked
5.7 So I'm getting the extra cubic
inches, better heads intake without
all the extra machine work required.
I'm essentially just gonna rebuild it
very close to stock specs, only real
differences are fully forged rotating
assembly, 10:1 instead of 10.3:1, diff
cam, injectors & a 84 hanging off of it.
Old 09-09-2018, 01:19 PM   #6
Chris
The stock 6.1 crank is already forged. All you need is forged rods and pistons
Tuned by Charged392
Old 09-09-2018, 01:27 PM   #7
I know the stock crank is forged I
was just thinking about replacing
the entire rotating assembly since
I'll likely be putting 18+ PSI onto it.
Old 09-09-2018, 01:34 PM   #8
Chris
I don't see the point of taking a good forged crank out and putting in a different forged crank for another $1000. As far as I know the crank can handle a ton of power, and its got the 4 bolt reluctor wheel, only issue I've heard is oiling issues with really high rpm like 7k+. Rick probably will chime in on that crank
Tuned by Charged392
Old 09-09-2018, 04:08 PM   #9
I guess I'm just a lil leery taking
a 180k to 225K stock crank and
putting 18+ PSI of boost on top.
Old 09-09-2018, 05:20 PM   #10
Chris
At 18 psi I would save that $1000 towards the RFE transmissions you’ll be eating every month haha that’s about the most boost that anyone in a ram is running, let alone in a heavy 2500
Tuned by Charged392
