6.1 Long Block into 03 Ram - Hemi Truck Club
Old 01-11-2011, 07:14 PM   #1
I found a good deal on a 6.1 long block. Can I swap this in and use my 5.7 heads, intake, and accessories? What, if any issues would I have to address....sensors, motor mounts, tranny, etc? I would at least be doing some mild head work and cam while I'm at it. I am aware of the 03 tuning issues, but still should be able to pick up some decent power, even on a mild build. Thoughts, comments? Thanks.
416_Demon is offline   Reply With Quote
Old 01-13-2011, 07:52 PM   #2
There shouldn't be any issues at all other than re-using the 5.7 front cover to keep the accessories in the same location. I would buy a new 5.7 harmonic dampener and port the heads.
Old 01-13-2011, 08:11 PM   #3
quote:I found a good deal on a 6.1 long block.
Do you mean short block? A long block comes with heads.
Any way, what stopped me from putting my 6.1 in to my truck, was the toner ring. The 03 uses a small number of teeth toner ring, the 6.1 uses a larger number of teeth. You might think, just change toner rings, but the 5.7 uses a 3 bolt, and the 6.1 uses a 4 bolt. Can't swap them. No one seems to know if the PCM in the 03, will work with the 6.1 toner ring. Too much work for me to try and find out!
Old 01-14-2011, 09:05 AM   #4
I am using a 6.1 block and crank and I assume 6.1 toner ring without any tuning to compensate for it.
Old 01-14-2011, 10:36 AM   #5
By what means, did you get yer 392 inches? See the Manley stroker crank info below. They offer both toner rings for their cranks. I would think, if one size fits all, they wouldn't offer two.
Old 01-16-2011, 07:31 PM   #6
Hemidup's Avatar
FrostKings 392 has an offset ground 6.1/3.80 stroke, 32 tooth toner ring crankshaft. 4.055" bore. Same as mine.
Old 01-16-2011, 08:21 PM   #7
I've never run across a 6.1 crank, that's 4 bolt, and 32 teeth. All the 6.1 I've seen are 58 tooth.
Old 01-17-2011, 09:00 AM   #8
Great info!!!!
Old 01-17-2011, 01:22 PM   #9
Hemidup's Avatar
I seen that Manley offered the 58 tooth toner ring. Same tooth count as an LSX. May help with HPTuners. ??? Here's pic's of 32 tooth count 4 bolt 6.1 crankshafts.
Old 01-17-2011, 02:17 PM   #10
Is that from a production 6.1, or specialty. I know Manley makes them. (See my chart above)
