'05 Dodge Ram 5.7 rebuild/upgrade - Hemi Truck Club
Old 12-19-2016, 08:58 PM   #1
Exclamation '05 Dodge Ram 5.7 rebuild/upgrade
Hey guys. I'm not too sure what happened, but as I was pulling off the interstate the other day and I came to the stoplight, something happened. As I started to drive away from the stop light I heard a knocking sound coming from underneath the truck. This sounded a lot like the issue I had before I put on my headers, but that if she went away. Now it seems that it's back and in a much stronger way. I believe I spun a bearing either the crank or a rod. Either way, I've already decided to take the truck in and have the engine rebuilt. While the engine is being rebuilt, I figured it's probably the best time I'll ever have to stab a new cam into it. I'm thinking about going with the Comp Cams 260. What I really want is for this truck to be a little bit more aggressive, but something I could still drive every day and feel is reliable enough to tow a trailer with a car on it. The guy who is rebuilding the engine is going to do new valve seats as well, as he says that's a common problem on these engines.
Here is where I need your advice. If I go with a new cam, do you recommend the 260? If not, what do you think would be the best cam for my application without going to a custom grind. Secondly, I need to know what else I need. Haha. I know I will probably need new valve springs, and a tuner for when it all gets put back together. I've listed my current mods below just so you guys have a good frame of reference.
Superchips 3815
Pacesetter LT's
Cat delete
DMH electric cutout
I appreciate all of your help. Looking to buy everything this week. Let me know if a local vendor can get me a hookup as well. Otherwise I'll try to swing a military discount with some of the bugger vendors.
DodgeGuy524 is offline   Reply With Quote
Old 12-19-2016, 09:04 PM   #2
Suggest springs and pushrods when going to any cam for added safety and what not always. Will likely need a little tune tweek in there also to get the best perfect from the cam.
Old 12-19-2016, 09:11 PM   #3
Thanks, Charged.
As for the pushrods, they'll be new OEM units. Would you suggest upgraded pushrods? Any specific brand?
Old 12-19-2016, 09:52 PM   #4
Comp or Manley are nice and cheap.
Old 12-19-2016, 09:58 PM   #5
Saw this the other day.
Comp Cams HEMI 5.7 6.1 2003-2008 XFI 260H-13 112-500-11 BRAND NEW - DODGE RAM FORUM - Dodge Truck Forums
As for push rods, you can't go wrong using Trend.
Current 1/4 mile [email protected]h (2018)
Old 12-20-2016, 07:38 AM   #6
ric3xrt's Avatar
I'm going to tag along here and subscribe.
Old 12-20-2016, 11:41 AM   #7
Enormous Member
Hugh Jassole's Avatar
I did similar to you a couple of years ago. Mods are in my sig. I went with the 268 and it behaves very well on the street, with a Jay Greene tune. Here's one thing you need to consider though, and it's bitten me in the *** 2x since the engine build. What are you going to do about a trans ? The stocker won't even stand up to a stock hemi. I'm now shopping for my 3rd trans, since the engine was built. I'm done with the 545rfe at this point. If I don't find a permanent solution, I'm going to put a stocker back in and sell the truck. I'll covert my Dakota R/T to daily driver status, and go by a low mileage SRT10 for a toy.
My other truck is an R/T
Old 12-21-2016, 05:21 PM   #8
Ariel
RAM4's Avatar
I feel the same.. The trans in my truck is the only reason I've even thought of selling my truck.
Old 12-21-2016, 06:14 PM   #9
Unhappy
This really has reached a critical point...someone out there must find a bullet-proof cure for a Hemi Ram with substantially increased horsepower .
Old 12-21-2016, 06:49 PM   #10
The fact is that trans swaps are not as big of a deal as they were a few years ago.
