03 to 05 pcm swap problems - Hemi Truck Club
Like Tree12Likes
Old 02-26-2019, 01:37 PM   #1
Waylon5.7's Avatar
I finally decided to do the 05 pcm swap on my 03 Ram 5.7. Everyone made it sound so simple and I haven’t had anything but problems. The swap itself was simple. But my problem now is that the truck won’t turn over, won’t click, nothing double checked all my wiring again everything matches up. It’s been starting up the past couple of days. I started it today to record a log and I let it stall before it started recording. Went to crank it back up and then that’s when nothing would happen. Keith has been working with me to tune it and he has helped out a lot with all of my questions and problems. Now I’m totally lost.
Waylon5.7 is offline   Reply With Quote
Old 02-26-2019, 01:48 PM   #2
So it has been starting using the 05 pcm? Started today, died and then wouldn't crank?
Old 02-26-2019, 01:51 PM   #3
Waylon5.7's Avatar
I’ve started it a few times today yes
Old 02-26-2019, 02:02 PM   #4
Waylon5.7's Avatar
It won’t turn over. It won’t click or anything. Battery has a full charge.
Old 02-26-2019, 02:37 PM   #5
Sounds like you have lost neutral/ park safety switch. Jiggle your shift lever.. or jump the saftey switch.
Old 02-26-2019, 02:59 PM   #6
Waylon5.7's Avatar
jiggling the lever didn’t work. Where’s the switch located?
Old 02-26-2019, 03:18 PM   #7
Chris
YeahItsAHemi's Avatar
Should be on the trans, not sure of the exact spot on the 545rfe. That could also be something with the trans wiring that got changed over. And triple check all the grounds
Tuned by Charged392
Old 02-26-2019, 03:24 PM   #8
Waylon5.7's Avatar
Can’t be any wire swap problems. It worked for a while after I did the swap.
Old 02-26-2019, 03:30 PM   #9
Waylon5.7's Avatar
I just unplugged the starter solenoid wire to see if any power was going through it. And the wire is not hot. This has got to be some dumb fix.
Old 02-26-2019, 03:37 PM   #10
Try disconnecting the battery and doing a reset.
