03 Hemi idle issues - Hemi Truck Club
Old 04-05-2017, 11:57 PM   #1
03 Hemi idle issues
Hey guys, been having idle issues with my truck since the battery died on me 3 weeks ago. It started off slowly & progressively got worse to the point where it won't even stay running anymore. I replaced the crank position sensor with no change at all. I replaced the APP sensor under the battery tray & that seemed to work for about a week or so with random stalling here & there. On Monday I disconnected the battery for about 4 hours to try & reset everything & after I reconnected the battery it refuses to stay running without my foot on the pedal. When it tries to run it runs rich as all hell. The motor has around 30k on it since I rebuilt it. Forged bottom end, Jay Greene custom cam, mild ported heads, 6.1 springs, SuperChips 3815 91 tune.
https://youtu.be/PyiFsUj3-OE
https://youtu.be/jMPhvpNtR14
rlk340 is offline   Reply With Quote
Old 04-06-2017, 06:14 AM   #2
Welcome to HTC.
Any codes yet?
Old 04-06-2017, 07:51 AM   #3
No codes at all. Only thing I got briefly when it stalled on me while turning into a driveway was the red lightning bolt but it went away when I restarted the truck. And that was before I replaced the APP sensor & crankshaft sensor.
Old 04-06-2017, 09:20 AM   #4
Who tuned it for the cam? The trims will be way off with most any cam and cause idle hunting like it is doing along with stalling and hard starting. I see you have a superchips 91 in there so it's not tuned?
Old 04-06-2017, 09:30 AM   #5
Jay speced the cam for the SuperChips 91 tune being that it's a 03. I've messaged him & sent him the 1st video & he's stummped on what it might be. Truck was running fine before the battery change.
Old 04-06-2017, 10:40 AM   #6
Old 04-06-2017, 12:20 PM   #7
I've found on the 03 after doing a reboot or tune install. Turn the ignition on and push the pedal to the floor and let it back up. Turn key off and then start the engine normally. The cam sensor can mimic the crank sensor symptoms. So if I change one I change them both. Running fat usually points at an exhaust Leake or o2s. Good luck..
Old 04-06-2017, 01:50 PM   #8
It is doing the same thing that most of the 04+ trucks do when the trims are way off at idle they hunt around and rev up and down till the trims are learned or tune dialed in
Old 04-06-2017, 02:00 PM   #9
My plans are to do a 05 PCM swap as soon as I get all the needed parts so I can get it tuned, but for now I just need to get it running right again. After I replaced the APP sensor I also put the truck back to stock tune & it ran good so after about, 4 days I reinstalled the 91 tune, ran fine with random stalling on me..most notably on the fwy doing about 30 mph when it it would die after letting off the throttle. I'll try what Greg suggested with the pedal & replace the cam sensor.
Old 04-06-2017, 02:56 PM   #10
When I used the 03 pcm Keith and I spent extensive time working on idle surg and trims. Since yours ran with your current setup it should be able to repeat that tune. Trims always need to mature to steady out. The problem with the 03 is if the trims mature and then the SC tuner modifies the mature trims. It can be difficult to get back to that original tune because you are starting from a different place. My suggestion is to toss the 03 pcm as soon as possible. Keith knows 03 pcm's better than most others. You need the ability to datalog to see what's going on. Good luck..
