will 4.7 5speed manual trans bolt up to 05 Hemi motor - Hemi Truck Club
Like Tree4Likes
Old 03-02-2019, 05:58 PM   #1
Looking for advice i have 1958 dodge d100 it has a 2000 dodge dakota frame and motor 4.7 5 speed manual I'm wondering if anyone who knows if the 5 speed manual will just bolt up to of 05 hemi i was told there the same belhousing for auto but i can't find any info on manual
d100 man is offline   Reply With Quote
Old 03-02-2019, 06:57 PM   #2
Yes it will bolt right to it issue free same clutch same flywheel same everything. Only diff between the two you will need a pilot bearing for the hemi for the trans input shaft is all it hammers into the back of the crank where the 4.7 uses a brass bushing.
I have this entire swap sitting in my barn trying to sell it to someone lol.
Old 03-02-2019, 07:05 PM   #3
Welcome to the forum.. I want your truck...
Old 03-02-2019, 08:11 PM   #4
thanks for the info any suggestion on wiring harness i need very little being that is for 58 gauges, stereo, heater, wipers, ignition, want to keep it clean also where u from i don't have the hemi yet $$$ how much u asking
Old 03-02-2019, 10:49 PM   #5
I meant just the trans swap setup the motor I have sitting there is not mine to sell so just trans setup for now is what I have. I’m in Florida treasure coast area!
Old 03-03-2019, 12:09 AM   #6
Old 03-03-2019, 12:37 AM   #7
Where are you located? The 4.7 pcm can run the hemi using a custom tune.
Old 03-03-2019, 01:38 AM   #8
Really nice Dodge. Please post up more pics of it.
Welcome to HTC.
Old 03-03-2019, 04:01 AM   #9
ric3xrt's Avatar
Love the 50s D-series trucks, tells us what you need and we will get you there. there is No shortage of Knowledge on this board when it comes to G3 Hemis
The NV3500 will hold up behind a mild G3 hemi , just have to be kind to it. No 4k clutch drops with 29X10.5 slicks ...one Question is it the low gear NV3500HD?
04 GTX...Under the Knife.
Old 03-03-2019, 11:09 AM   #10
Thanks for the welcome to this group, and all the speedy replies not sure how to tell if its a low gear. I lost original ownership for the Dakota it came from. Are the transmissions stamped somewhere?
I guess to start with this is what I'm up again. Its a 2000 dodge Dakota frame i was told to use motor mounts from a dodge Darango to put the Hemi on and i don't need all the wiring harness so should i have a new Ecm and wiring harness made based on my project? And hew would everyone recommend to make it?
