Weak brakes after removing intake box - Hemi Truck Club
Old 10-16-2016, 11:44 AM   #1
Unhappy Weak brakes after removing intake box
I need help solving a lack of brake power. I removed the intake off the motor when I removed the head. I wanted to repair a broken valve spring, bent push rod and check why it broke. After replacing the head gasket and the head, I reinstalled the air box and other parts. I now have no power brakes or a/c. Please give me some assistance in finding where to look. The cooling fan is running as if the a/c is on, but the compressor is not turning.
tool633 is offline   Reply With Quote
Old 10-16-2016, 11:50 AM   #2
Did you re-attach the vacum hose coming from the intake Manifold to the brake booster?
Old 10-16-2016, 11:57 AM   #3
I replaced the air line coming from the back of the intake to the brake booster, but there is a second hose bib on the front of the brake booster. Should it be closed?
Old 10-16-2016, 12:11 PM   #4
The smaller of the two vacum hoses goes to the purge valve. The small nib on the booster check valve is usually capped
Old 10-16-2016, 06:44 PM   #5
MikeHTally's Avatar
The A/C part may be a missing connection to the compressor. There is a small vacuum connection to the intake near the throttle body. That one popped off when I did my valve spring project.
Old 10-21-2016, 11:17 PM   #6
Thanks to both of you for the response. It was vacuum lines. All is well and the '06 is back to work
Old 10-22-2016, 04:09 AM   #7
Old 10-22-2016, 05:18 AM   #8
Nicely done...
Old 10-22-2016, 08:54 AM   #9
Lightbulb
If you like gauges - add a simple 'old school 60's style' vacuum gauge to your truck - it can help with simple diagnostics and give some indication of where your fuel mileage might be in real time as you drive...but I really just like seeing the needle jump-around .
Old 10-22-2016, 09:10 AM   #10
Everyone needs a vacuum gauge! I really like mine when it swings to the right of "0".....
Tags
bad brakes/no a/c
