Vapor canister replacement - Hemi Truck Club
Like Tree2Likes
Old 04-27-2018, 04:51 PM   #1
Sleeperhemi's Avatar
Hi folks! Hopefully someone has some good news for me. Long story short....been fighting a P0457 code for quite a while now. So far I have replaced a gas cap, purge valve, NVLD and o-ring, every hose on top of the gas tank(clamped any without quick connects). Inspected all the plumbing all the way up to the engine as well. Had the system smoke tested and no leaks were found. The shop cleared the codes, CEL stayed off the entire day until yesterday morning.....TADA...P0457. Last thing to replace is the charcoal canister. Anyone know if that can be removed easily or is this a "bed off" or drop the tank deal? Replacing it on my 2011 Ram 1500 crew cab 4WD with the 26 gallon tank.....any info would be greatly appreciated. Thanks!
Sleeperhemi is offline   Reply With Quote
Old 04-27-2018, 06:58 PM   #2
Most times that code is for the NVLD switch but if that’s new then that’s not the issue. Who smoke checked it? Did they test the entire system from the purge valve upfront all the way to the rear? This system is not like the older stlyes it requires pluggin off the vent valve in the rear. If they tested it correctly the machine will show no flow on the flow table did they get a no flow condition and I mean ball steady not vibrating?
Old 04-27-2018, 08:36 PM   #3
Thank you for your response! It was smoked at a very reputable shop in my area....rather large shop with all the latest and greatest. Been going there for years and never once had an issue, I trust them. The tech who always handles my vehicles said he smoked it front to back....then back to front and found no leaks. opened the purge via scan tool and functioned well. Didnt mention anything to me about flow conditions......not saying he didnt see that on his machine....just didnt say anything to me. They had my truck for 8 hours and couldnt find anything. Also, the nvld i replaced is the 2nd replacement. First was from a parts store......i just replaced it again with an oem dealership part including new o-ring.
Old 04-28-2018, 07:07 PM   #4
Replacement gas caps can be problematic at best. Long ago when I had leak problems I replaced the cap several times before finding one that actually sealed. You can use vaseline on the rubber seal to help seal the cap. The nvld hoses and clamps can be a problem but have smoke tested, you've replaced the nvld. This could be electrical. The plug/wiring and I remember there is a 5v monitoring circuit provided by the pcm to monitor the nvld circuit to test to see if the nvld is plugged in. Probably need a scanner to check that. Good luck..
Sleeperhemi likes this.
Old 04-28-2018, 09:38 PM   #5
And you called it right. Was underneath the truck today checking over everything again and what do I find way out of my reach? A chewed thru wire coming off the nvld connector.Conveniently I can barely see it, top side of the tank just inside the frame where another wire harness runs....took the wheel well liner out, still cant get it. Back to the shop we go.
Old 04-28-2018, 10:16 PM   #6
Time and time again I find the owner catching the problem when the shop misses it. Well done...
Old 04-29-2018, 06:27 AM   #7
It happens but they deff should have seen that with a scanner monitoring pressure during test. Emmisions tests are a real pain in the but you have to be really thorough when doing those tests as just about anything can trip that light.
Old 04-29-2018, 07:27 AM   #8
I believe a device can be plugged in to replace the nvld and trick the pcm using a resister and relay. Basically the resister would simulate the nvld internal switch (relay) and the external relay would replace the nvld sensing tank pressure. It's been years since I wrote the posting, but it's buried somewhere no doubt. If interested, go through the service manual and review the nvld wiring circuit.
Old 04-29-2018, 02:31 PM   #9
That is 100% not a possibility lot the new switch is in no way a sealing device. The nvld now uses tank temp and natural gas expansion and contraction of the fluid along with a time period to test for leaks. Smoking them is to find leaks but 90% of the diag to this new system is the electrical side of things. Fix the wire and let’s hope it’s done after that.
Old 04-29-2018, 04:33 PM   #10
That is 100% not a possibility lot the new switch is in no way a sealing device. The nvld now uses tank temp and natural gas expansion and contraction of the fluid along with a time period to test for leaks. Smoking them is to find leaks but 90% of the diag to this new system is the electrical side of things. Fix the wire and letís hope itís done after that.
Keith you know my knowledge base is centered around 03 model rams. This was the first year the nvld was used with rams. I deconstructed the system years ago and have no idea what the geniuses have now come up with. Off the top of my head the circuit uses natural expansion within a sealed tank. The pcm does event timed test first looking to see if the device (nvld] is plugged in and then whether (test) there is internal tank pressure needed to close a switch (nvld). The federal emssions controls usually work at two levels. 1st for the pcm to confirm the device is operating and 2nd for the emission device to detect a condition be it electrical reading, pressure , temperature or vacuum.
To categorically call bs without an explaning doesn't provide any information and is frankly rude. We are all here trying to help our hemi community.
