Throttle Control Warning Light - Hemi Truck Club
Old 12-01-2016, 05:07 AM   #1
jwberry's Avatar
I have had rough running conditions under both idle and while applying gas, would get the p0300 code. Yesterday my truck would crank but not start, this throttle control warning light came on and did not go out after 3-5 seconds, I did NOT get an engine light.
I unfortunately have no choice but to get it towed to a local shop. What all components are involved with the Throttle Control System? Anything else that can cause this? I'm not clueless just want to make sure I have my ducks in a row.
jwberry is offline   Reply With Quote
Old 12-01-2016, 07:26 AM   #2
jwberry's Avatar
*Update* The throttle control warning light turns off after about 10-15 secs. and now the engine light IS on. The battery voltage gauge is showing low voltage, but the engine cranks fine, just will not start. Like it is not getting fuel.
Has a new fuel pump and I can hear it engaging.
Old 12-01-2016, 09:48 AM   #3
Do have a test fitting on the fuel rail? You could check for pressure. Replace the battery and fully charged it. Clean terminals and grounds. Check electrical connection to the TB, clean and use a little dielectric grease. Pull a plug on each bank to see if it is wet with fuel or dry. This should get you started. Good luck..
Old 12-01-2016, 11:36 AM   #4
jwberry's Avatar
No pressure from the fuel pump at all. It was trying to turn which is what I was hearing from it, but wasn't doing anything. So the f'en pump was no workie workie.
I did clean the TB and connections a while back, but will do that again. Also having the battery charged, it was fairly new so I'll just keep an eye on it.
Old 12-01-2016, 12:15 PM   #5
Good it sounds like it's the pump. If you take the gas cap off and listen you can really hear the pump running when it's working. If it sounds like it's got no load on it. It may be the fuel pickup fell off inside the tank. Of course....
Old 12-01-2016, 12:34 PM   #6
Exclamation
Could be the 'new' fuel pump is bad/defective . Unfortunately in today's world parts aren't what they use to be in many cases .
