Starting Issues - Hemi Truck Club
Old 10-03-2016, 11:36 AM   #1
F.D.Jr.'s Avatar
Starting Issues
Hello Ram Family. Need A Little Advise. My 2012 Hemi 5.7 V8 Quad Cab, every once in a while, I will hit the key and it won't turn over. Sounds like a starter solenoid to me. 10 seconds later it starts like nothing is wrong and it will roll fine for like a couple weeks and then again I get the same situation where it like the solenoid going out. Is that what my problem is, or is it something electrical that I have to have the dealer look at?
F.D.Jr. is offline   Reply With Quote
Old 10-03-2016, 01:23 PM   #2
Enormous Member
Hugh Jassole's Avatar
I'd try tightening all the battery cables 1st, both ends
My other truck is an R/T
Old 10-03-2016, 01:54 PM   #3
F.D.Jr.'s Avatar
Checked and good. Also checked the connections going to starter and also ground connection. All are good and tight. Could it be something electrical maybe with the key fob that Chrysler/Dodge gives with these trucks?
Old 10-03-2016, 04:39 PM   #4
MikeHTally's Avatar
Does it have remote start? If not, it can't be the fob. A key is a key. If it turns the ignition switch, it works. How many miles? It's a bit early for battery failure. Do you make a lot of short trips?
Old 10-03-2016, 06:35 PM   #5
F.D.Jr.'s Avatar
The key fob does not have remote start. Only panic, lock, and unlock, and we drive about 75 miles a day during the week for work. Battery is good. And connections are good. I had fobs tested and battery inside of fobs and they are good. Millage is at 104,000 and some change.
