Stalling - Hemi Truck Club
Old 12-14-2016, 06:33 PM   #1
Stalling
I have a 2012 1500 5.7 I drove it this past weekend 350 miles everything fine woke up next morning drove it 5 miles died would not start without my foot in throttle got it home and same thing would not start without foot in throttle bit soon as I release throttle instantly dies acts like no gas. To this point I have scanned and came up with the lovely p0301 code so I have changed all plugs and cylinder on coil pack with no results have a injector to throw in bit looking for other answers before hand all info would be greatly appreciated
Mikeyshea0523 is offline   Reply With Quote
Old 12-14-2016, 06:34 PM   #2
Would also like to mention when I took cylinder 1 coil pack off it had the burnt smell to it
Old 12-14-2016, 09:03 PM   #3
Inspect the coil that had the burnt smell to see if it cracked or swollen.
Old 12-15-2016, 05:16 AM   #4
There doesn't seem to be anything physically wrong with it
Old 12-15-2016, 05:19 AM   #5
Also would like to add when it is running at 1000 or 2000 rpms vibrates bad but 2500 3000 no vibration really seams like no gas but could one I jector keep truck from idling
Old 12-15-2016, 05:56 AM   #6
Did all the spark plugs look the same? If you have headers you can use a squirt bottle of water and squirt each cylinder and see if any are cooler than the rest indicating it not firing. Compression check would eliminate a mechanical problem. Really not familiar with the newer mds models. But sounds to me you have a cylinder not firing. If you can determine if it is one of the cylinders that deactivates it could be a failed lifter. Good luck..
Old 12-15-2016, 06:11 AM   #7
Queen Kima - Whemi BOD
Mrs.Studmuffin's Avatar
Old 12-15-2016, 06:45 AM   #8
Cylinder 1 plugs were gummy compared to rest
Old 12-15-2016, 07:22 AM   #9
Would you still have those plugs to take a picture of? Was that the cylinder that the burnt smelling coil on? Could you tell if that was gas rescue or oil?
Old 12-15-2016, 09:28 AM   #10
I no longer have plugs but yes that was the #1 cylinder I replaced coil on they all had a small amount of burnt oil and gas mixture but 1 was really bad actually had a build up on plugs
