Squeaky pulley tricks? - Hemi Truck Club
Old 11-03-2016, 05:13 PM   #1
JustHemi's Avatar
I replaced the serpentine belt on my truck the other day but I am still having a squeak. Anybody have quick tricks for isolating which pulley it would be? Last for about 15 minutes when I started cold and then goes away.
Old 11-03-2016, 06:54 PM   #2
I shoot WD40 on each pulley one at a time until it stops.
Old 11-03-2016, 07:26 PM   #3
Grab a spray bottle of soapy water and mist the belt and see of the noise goes away or not first I have seen new belts squeak sometimes also. Next look for a pulley alignment issue. After that then play with isolating pulleys and what not.
Old 11-03-2016, 08:13 PM   #4
JustHemi's Avatar
So if it IS the new belt, then what....? Spray it with that belt antisqueak spray or something that is longer lasting? It is actually worse since I put the new belt on.
I actually did spray a few of the pulleys with WD40 tonight. Hadn't helped right away, but maybe after it sits and penetrates a little.
Amsoil Dealer (Greenwood, IN)
www.lubedealer.com/indyoilguy
Ph#: 317-383-6061
Many mods to come....hehehe.
Old 11-03-2016, 09:03 PM   #5
If it makes more noise sometimes then new belts are junk have run into it before
Old 11-03-2016, 09:14 PM   #6
JustHemi's Avatar
[email protected]#%$$.....It was a better one too....Had a 3 year warranty. Maybe just take back and exchange it if the soap trick works.
Ph#: 317-383-6061
Old 11-03-2016, 09:15 PM   #7
JustHemi's Avatar
On a side note....since it seems to go away after it warms up, would that tend to point more towards the belt as well? Would a pulley squeak even go away typically?
Ph#: 317-383-6061
Old 11-03-2016, 09:41 PM   #8
JustHemi's Avatar
Well I got my question answered. I sprayed some soapy water on it and it instantly went away. Looks like I will be redoing the belt again. LOL.
Ph#: 317-383-6061
Old 11-03-2016, 10:03 PM   #9
Make sure the pulleys all spin smooth and even. The tensioner could be coming apart or another pulley wobbling when spinning causing the squeak.
"CMR TUNER" [email protected] 1/4 with a 7.32 1/8 custom long/short bars by "Me" Turbocharged 392 on 9psi S475/96/1.32 . Running thru an A518! 690[email protected]
Old 11-04-2016, 10:47 PM   #10
JustHemi's Avatar
I replaced the belt tonight.....seems good so far. Sat for 5 hours and didn't squeal....in 50 degree weather. So we will see. If anything tensioner seems a little aged if anything on the belt change so I can change that if need be....
Ph#: 317-383-6061
