Removing rear brake rotors - Hemi Truck Club
Like Tree6Likes
Old 02-10-2019, 06:32 PM   #1
Loucks2000's Avatar
Trying to replace rear brake rotors but can't get rotor off, I backed emergency brake off but won't slide off any hits didn't want to hit with hammer?
Loucks2000 is offline   Reply With Quote
Old 02-10-2019, 07:35 PM   #2
If the rotor wiggles then it’s likely not stuck on the hub so it’s more than likely stuck on the parking brake but only if you use it a lot not very common to hang up on that. Of the rotor is not free of the hub give it a wack with a hammer from the back where the caliper bolts on and free it from the hub
ric3xrt likes this.
Old 02-11-2019, 06:54 AM   #3
Queen Kima - Whemi BOD
Mrs.Studmuffin's Avatar
Old 02-11-2019, 12:13 PM   #4
Tyler
TYSENUS's Avatar
wedge a block of wood in behind and then give it a good whack.
Mods:
Old 02-11-2019, 04:10 PM   #5
Old 02-11-2019, 04:16 PM   #6
Gold-Member
kcd1369's Avatar
Is the truck pretty new? First time rear brakes were done? There are normally a retainer or 2 on one or more of the studs that hold them on. With older trucks you wouldn't notice them due to being removed already.
Old 02-12-2019, 10:03 AM   #7
Red Trucker
HemiLonestar's Avatar
Take a wire brush or dremel with a small wire wheel to where the center register meets the rotor. Get rid of as much of the guaranteed corrosion is there, then spray with your favorite penetrant (WD40, Kroil ,etc). Give it a little while to soak in, then start wiggling it. If it doesn't wiggle right away, give it a whack with a small sledge, then rotate it so you can hit it again on the opposite end. Repeat til she pops loose. It WILL pop loose.
Old 02-13-2019, 07:09 AM   #8
Titan Up
Saving Lives's Avatar
When I did mine I had to whack it with a hammer quite a few times. If your worried about damage then try a heavy duty rubber mallet. Some penetrating oil might help a little bit too.
Chance favors the prepared mind.
Saving Lives is offline   Reply With Quote
Old 02-13-2019, 02:19 PM   #9
Gold-Member
kcd1369's Avatar
Originally Posted by Saving Lives View Post
had to catch it in the coat and whack it with a hammer!
Old 02-14-2019, 03:28 PM   #10
TooCool's Avatar
Give this a try!!!
SUPER BEE likes this.
