removing leaves. - Hemi Truck Club
Old 03-04-2016, 06:42 PM   #1
removing leaves.
I'm new to the Ram world. I just bought a 2011 standard cab Hemi. I love it. I noticed in the door jam that leaves( from a tree) were stuck behind the hinges. So I started to remove them and noticed that more were sticking out from behind the foam. I stuck my fingers back in there and could feel alot more behind the lower fender by the door. So I took off the plastic shield off at the lower corner of the fender and then loosened the inner fender. I removed about 2 handfuls of old wet leaves. These were rust causing type leaves that would probably stay moist most of the time. I checked the passenger side and it appeared there were no leaves. I went ahead and removed the inner fender and found almost as many on that side. FYI, it may be something to check, especially if you own a used truck. It is a problem I just happened to run across. But it is one that could potentially cause rust within the fender. Good luck.
connman24 is offline   Reply With Quote
Old 03-04-2016, 08:31 PM   #2
Yes they tend to collect there that's for sure!
Old 03-04-2016, 08:45 PM   #3
Hmm how do they get in there with the hood closed?
Old 03-05-2016, 02:46 AM   #4
Board of Directors-Bill
arocketman's Avatar
Good to have you here. Glad you were able to get to those leaves. Yuck!
05 QC
BLUE MAX
"Slightly Tweaked"
Just [email protected]
Old 03-05-2016, 04:46 AM   #5
Gregg you would be surprised but yes they do cluster down there. A good place to keep clean along with the rear fender lips
Old 03-05-2016, 08:09 AM   #6
Is this the area between the inner fender and the cab?
Old 03-05-2016, 08:19 AM   #7
Yep mainly down near the bottom area
Old 03-05-2016, 08:55 AM   #8
connman24
Old 03-05-2016, 08:57 AM   #9
With as often as I pull the inner fenders I'll never collect anything in that area. Might be worth while to pull the liners and spray some under coating in there.
Old 03-05-2016, 02:20 PM   #10
Queen Kima - Whemi BOD
Mrs.Studmuffin's Avatar
