Redtruck's never ending tale.... - Page 506 - Hemi Truck Club
Like Tree1177Likes
Old 09-25-2019, 11:28 AM   #5051
It's been 35 years since I was spraying heavy metals and 15 years since heavy exposure to anti-fouling materials. Unfortunately I have copd which affects me to varying degrees day to day. I count myself very lucky. There is a lot of nasty stuff out there that can ruin your health if not safely handled. May you all have good health..
May you too have better days of health.
bada44 likes this.
Old 09-25-2019, 11:41 AM   #5052
Thanks John..
Carried some pieces to the machine shop. Experimenting with some different spring setups trying to workout a compromise of rocker arm clearances and seat pressures. We're on the fourth set of springs.
bada44, ric3xrt and oldmanram like this.
Old 09-27-2019, 04:42 PM   #5053
The front cover has two hollow dowels to locate the cover (seal). I had to remove them from a core engine I have. Of course they didn't just fall out. So I soaked them with penetrating oil. Filled the hole with grease and tried hammering them out. No go.. heated them and tried twisting them out .. no go.. then screwed a 3/8" tap partially into them using a T wrench and success, they came out with little effort. The next step would have been to screw a 3/8" bolt into the dowel and then screw a nut, washer and shell down onto the block extracting the dowel.... there is always a way to work those pesty blind holes...
SUPER BEE likes this.
Old 09-27-2019, 07:51 PM   #5054
ric3xrt's Avatar
Thanks John..
Springs are a b!tch you guys know you can use LS double springs...
Redtruck-VA likes this.
Old 09-27-2019, 08:10 PM   #5055
Ric, the LS has the most selection and most likely it'll be one of them...
Old 10-04-2019, 12:08 PM   #5056
Took the sniper valve covers to the shop to check for fit. I'm using stanke valve train girders, clamps and shafts on edelbrock heads. Short story is they don't fit right out of the box. It'll take some machining and mssaging to get them to clear and seal. Stock valve covers... no chance..
Old 10-04-2019, 10:37 PM   #5057
oldmanram's Avatar
I'm thinking of using the Stanke Girders /Collars as well , on my 03-08 5.7 heads.
They don't have clearance problems do they ?
It's the springs/rocker combo your using
Old 10-05-2019, 02:07 AM   #5058
There are a couple problems. The dimension from the spark plug flat to base seal is about .150" off. If I cut the spark plug flat rubber seal in half it'll pull down properly. And then the coil boxes on the Sniper cover interfere with the Stanke girders and will need some grinding. I briefly sat the Sniper cover on a stock 05 head and didn't see any obvious problems. The fitment issue is the edelbrock head, Stanke and Sniper combo. I sat a (06) oem cover on the edelbrock head and it was obvious there was a lot of interference happening and it was a no go. The Stanke girders are thicker than oem shaft clamps. This raises the head of the hold down bolt. May need to trim the bolt head. I'm going to go over everything again monday. I find it hard to believe edelbrock would change the basic sealing dimension of the spark plug flat to bottom seal.
Old 10-05-2019, 06:17 AM   #5059
Re-read edelbrock sale pitch discription and they state the edelbrock head can use oem valve cover, so it must be the Stanke/ Sniper combo that is the issue...
Old 10-07-2019, 10:02 AM   #5060
The problem was a slight interference with the Stanke girder and Sniper cover. Also the collars needed a little massaging to get .035" clearance with the spring. I suggest just take your time and fit each piece as necessary. Stock head might fit without issues. But the bottom line is its a strong setup and it does fit...
ric3xrt likes this.
