random multible misfire - Hemi Truck Club
Old 05-17-2015, 03:40 PM   #1
got an 05 ram,5.7 bought it last year with 97k on it now its at 140k ,ran great until came out from work ,started it and it started missing terribly ,threw out p0300 code ,cleared code and seemed to run good again ,next morning started it and miss was back but went away after getting to normal temp so i changed spark plugs ,improved a lil but still missed untill warmed up then it gradually got worse started missing constantly so thought had bad coil n changed them all,still having cold start miss and slight stumble right off idle still throwing p0300 code .seen in other posts people talking bout broke exhaust springs may be the culprit but was wondering if certain cylinders were more susceptible than others and if anyone could recommend a brand that is not prone to this if this is my problem
bill b is offline   Reply With Quote
Old 05-17-2015, 03:57 PM   #2
Does it stall at idle? Possibly egr valve issue stuck open. Get a good scanner and it should be able to show cylindrr contribution at idle basically idle misfire monitor. Cylinder 1/3 seem to be problematic on the 2005 range engines.
Old 05-17-2015, 04:09 PM   #3
no stall on idle,i unplugged the egr to see if was any change then reset comp (saw to do that in different post)
Old 05-17-2015, 05:04 PM   #4
Well may still be stuck open with truck idling does egr tube get hot it should be cool to touch at idle since it's not working then. It will be hot may burn if not careful if flowing at idle. If that's not the issue you will need a scanner to narrow it down a little more
Old 05-17-2015, 07:03 PM   #5
after 5 min idle pipe did get hot,gonna get a egr tomorrow and try that ,thx for the info
Old 05-17-2015, 07:04 PM   #6
How hot can't hold hot? If so pull it off and see if there is a piece of carbon stuck in it
Old 05-17-2015, 07:17 PM   #7
didnt get so hot you cant hold it but did get hot im just gonna replace it ,its cheap enough and got 40 k miles on that part so no biggie
Old 05-18-2015, 06:08 PM   #8
new egr took away the miss and the stumble at right off idle is getting better,might just need to drive it more .thx so much for the advise
Old 05-19-2015, 03:55 PM   #9
spoke too soon frikin thing acting stupid again
Old 05-19-2015, 04:43 PM   #10
make sure the evap purge vakve under the fuse box is not hung open. Pull the lines off it and try and blow thru it if there's flow it's stuck. If that is fine then you will need a scanner to narrow it down a little better
