PS Fluid in Inner Tie rod boots? - Hemi Truck Club
Old 08-04-2017, 06:54 PM   #1
Heywood's Avatar
Question PS Fluid in Inner Tie rod boots?
Last time I was at the dealer they indicated the left inner TR had excessive play. Turned out to be the hub but that's another story.
So while I was replacing the upper and lower ball joints today I went ahead and replaced the inner and outer tie rods / ends. I already had the parts so I went ahead and did the inners anyways even though they didn't feel as bad as I would expect for 223k mi.
As I pulled the boot, to my surprise it dumped PS fluid all over my driveway. I have to say I don't think this is normal. Both sides did it (but I was ready with a catch pan the 2nd time). Are there seals that I can replace or do I have to replace the whole rack?
2005 1500 QC 4x2
Heywood is offline   Reply With Quote
Old 08-04-2017, 07:30 PM   #2
It's normal for them to sweat a little over time but if it ran out when you pulled the boot off it's likely time for a rack and pinion. The seals in there are not serviceable to my knowledge.
Old 08-05-2017, 01:53 AM   #3
The rack on my truck has mysteriously repaired itself a few times. After sitting for an extended period of time it has dumped fluid on startup. The first time it did this, the inspection sticker had expired and needed the truck on the road immediately. I used brake cleaner and got the mess cleaned up. Topped off the resovior and had it inspected with full intentions of replacing the r&p. It didnt leak for a couple more years, again after sitting for a few months. My son in laws 04 did the same thing. Seems if the old truck sits for more than a month it pukes fluid then goes back to being sealed. If its leaking from the high pressure hose. Putting a hose clamp on it solves the problem. Its just a bit quirky....
Old 08-05-2017, 08:28 AM   #4
Heywood's Avatar
About 6 mos ago I replaced both lines from the cooler. I tried new hose clamps, and that worked for a bit but the leak returned. Haven't seen a drop since new hoses. Cheap fix too, < $30 IIRC. The dump of fluid from the boots was a surprise.
ETA:
@Charged, yeah it was more than a little 'sweat'. Open a bottle of new fluid and turn it upside down on the driveway...
2005 1500 QC 4x2
Old 08-05-2017, 08:49 AM   #5
Oh damn yeah not good that's to much
