Power Window problem - Hemi Truck Club
Like Tree4Likes
  • 1 Post By charged392
  • 2 Post By megacab1
Old 04-07-2018, 05:19 PM   #1
Unhappy Power Window problem
I'm the original owner, I have a 2007 Dodge megacab. Rear passenger door window will go down but not up. I checked the switch and swapped the front switch for the rear one and still, the window goes down and not up. I used a grounded test light and tested the plug at the motor and I'm getting power to both. I figured the motor was bad so I bought a new one. The new one does the same thing as the old one. Down but not up. What am I missing?
megacab1 is offline   Reply With Quote
Old 04-07-2018, 06:47 PM   #2
Someone will help you soon with your window problem.
Old 04-08-2018, 07:04 AM   #3
Mega cab open the door and check the wiring in the door jamb they always break there is actually a new door harness available with wires that flex a little better and don’t break.
Redtruck-VA likes this.
Old 04-08-2018, 10:11 AM   #4
Mega cab open the door and check the wiring in the door jamb they always break there is actually a new door harness available with wires that flex a little better and donít break.
Does that wiring harness also apply to the quad cab models?
Old 04-08-2018, 11:21 AM   #5
charged392
would a broken wire in the harness keep the window from coming back up?
Old 04-08-2018, 01:28 PM   #6
BIG THANKS, to Charged 392. It was a broken wire in the harness.
CavRam and SUPER BEE like this.
Old 04-08-2018, 05:45 PM   #7
Keith
Old 04-08-2018, 08:21 PM   #8
It’s always the mega cans too it’s annoying that’s for sure. Glad you found it. You can fix the wire yourself at work if a customer wants to be a little cheap on the fix we use flexible speaker wire of the same gauge and just extend the broken wire a touch in the middle area
SUPER BEE likes this.
Tags
power windows
