Plugs etc. - Hemi Truck Club
Old 06-23-2016, 10:18 AM   #1
Enormous Member
Hugh Jassole's Avatar
Plugs etc.
What is everybody using. My builder put iridiums in there and I'm starting to get an occasional misfire when cold. I'm also using Taylor Shorties, they're about 2 yrs old. They are getting swapped out too. Also, are the aftermarket MSD or Accel coils worth the extra coin for anything but looks. Still have the originals in there and out 156K miles, they are probably tired too.
My other truck is an R/T
Old 06-23-2016, 10:25 AM   #2
Coils have had a lot of discussion about them. I have heard more complaints about shorty's than with stock wiring. I replaced my 03 coils with salvage yard 06 dual coils a couple years ago. No complaints, fairly recently I replaced them with SoS coils. And I still have no misfire or complaints. Pretty much your choice.
Old 06-23-2016, 10:29 AM   #3
I've been running champion plugs, Im having a misfire to from time to time an think it maybe the wires cause I'm pretty sure there stock
Old 06-23-2016, 10:41 AM   #4
It's the cam likely Mario the missfire monitor needs raising a little bit.
Old 06-23-2016, 11:13 AM   #5
Enormous Member
my pops are through the exhaust, unburned gas. and it goes away once the engine warms up a bit. usually only happens above 4K rpms
Old 06-23-2016, 12:35 PM   #6
Enormous Member
anyone else on spark plugs ?
Old 06-23-2016, 04:26 PM   #7
tui
tui's Avatar
Only running stock Champions here. While its my daily driver our speed limit is 60 mph max so the truck never gets pushed.
I'm taken by the regular comments aired here which suggest 100 thousand miles on a truck is considered a low mileage. Here its looked at as being high.
Old 06-23-2016, 07:18 PM   #8
MikeHTally's Avatar
NGK 5306s in both Hemis here. Each is on its second set.
Old 06-23-2016, 11:10 PM   #9
On my 2007 Dodge Ram 1500 Quad Cab Hemi, I run CHAMPION COPPER PLUS 570 Spark Plugs. No problems at all with the plugs or coils.
Old 06-24-2016, 07:39 AM   #10
Enormous Member
NGK 5306 {#LZTR4A11} V-Power Info
V Power Spark Plug; .044" GAP
Getting these, what's the usual expected life out of a normal plug like these. As opposed to iridiums etc ?
