Pcm flashing questions? - Hemi Truck Club
Old 03-11-2017, 07:55 PM   #1
94half ton hemi
94swapped's Avatar
Can anyone tell me if it is possible to remove certain things from a 2003 ram pcm. Such as evap system and change from aw abs to rw abs. Remove airbag controls remove HVAC just so I Ave no codes there are no airbags or HVAC controls in my truck as I am running the 1994 HVAC Which is vacuum controlled
Sorry if this is posted in the wrong area
Thanks in advance
94swapped is offline   Reply With Quote
Old 03-11-2017, 09:22 PM   #2
The 03 pcm being the bastard child of the hemi pcm's is limited in what can be done with it. I don't know if cmr tuning can tune off the emissions. A custom flash from B&G can turn it off. But with that said I wouldn't waste the money having it done on a 03 pcm. I'd recommend first swapping in a 05 pcm and then decide what you want to have done to it. I speak from experience, the 03 pcm is a troublesome pos.
Welcome to the forum. Tell us more about what you have done... sounds interesting.
Old 03-16-2017, 08:46 PM   #3
94half ton hemi
94swapped's Avatar
I'll start a new thread about my truck called "what I have"
On the subject of pcm I've read a bit about switching to 05 pcm but I thought that involved also switching wirring harness and other components along with it in order to run properly. Or is it just plug and play for the pcm alone?
Old 03-16-2017, 09:13 PM   #4
A few of us have swap to an 05 pcm from a 03. My truck isn't a good example as I have a 96' 46rh trans in it running stand alone. You would need to remove the 03 tcm and move the wires over to the 05 pcm. There are a couple threads that cover what needs to be done for the swap.
Old 03-17-2017, 08:52 PM   #5
94half ton hemi
94swapped's Avatar
Oh ok well I'll do a search and have a look around see if I can get my hands on some parts ....is it just 05 or is it possible with 06 or early 07 ?
Old 03-18-2017, 12:17 AM   #6
I would stay with the 05 pcm. You want to stay clear of the years with mds.
Old 03-19-2017, 11:43 AM   #7
94half ton hemi
94swapped's Avatar
ok thanks. another question. is there any changing of software needed to do the swap like do I need to program the PCM to match my SKIM and Cluster or should it be just plug and play besides the swapping of pins for the TCM to the 05 connector and the 02 sensors?
03 swapped 1994 half ton 4x4 mostly stock 😛
Old 03-19-2017, 01:14 PM   #8
I've never had skim on my truck so haven't had to deal with any of it. I have used both new a salvage yard pcm's and just plugged them in. The 05 pcm I have I bought new and had B&G flash it for what I wanted. Never gave skim a thought.
Old 03-27-2017, 09:14 AM   #9
Red Trucker
HemiLonestar's Avatar
Those kind of changes require OEM level engineer's software.
2012 SRT Charger & 2003 Hemi Ram
Old 03-27-2017, 10:01 AM   #10
Just a note: B&G is flashing custom tuning using pcm oem code.
Tags
delete, flash, pcm, program, remove
